TREX cam, what springs?
NO they will not work, and if they do work they will not work very long. You'll need a dual spring set up that is rated to hold the lift of a TRex, which is .608/.612 assuming a stock rocker or stock rocker ratio. Thunder Racing recomends either a Crane Cams dual spring set up and they offer a Comp Cams dual spring for an additional $250. Good luck and buy some ear plugs
Everyone I know, myself included, runs the PRC springs with all of our big cams. Not a bad price either, here's a link:
http://www.texas-speed.com/shop/item...d=173&catid=48
Originally Posted by V6 Bird
you can read cant you?
'91 LX Coupe - Black, LS6 block, scat H beams, Mahle pistons, MS4 Cam, TSP1.0 CNC LS6 Heads (.040, 11.5:1), Victor jr Intake, Speed Demon 750, AJE tubular 4.6 k-member, AJE tubular lower c/a's, gran coil overs, lakewood 90/10's, 50/50 rears, tubular upper/lower rear control arms, moroso trick rear springs, TH350 w/4000 stall, and a NOS Direct Port. Tagged & Inspected.
Do tell!
