stock rods are typically good for XXX hp?
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
ya what are the limits of the stock connection rods, i have a 92k mile ls1 i want to do h/c on but not sure if i should forge it or just leave as it is...
Man, it was only 4 hours from the beginning of your post
Stock rods are good to 500-550ish rwhp usually, but YMMV. You should have no problems with them on a H/C setup. Dom was also right in that the rod bolts are the weak part when revving high. Stock rod bolts are typically good to 6500-6800 safely, depending on the year (01+ were the better bolts). I put new rod bearings in and ARP bolts, and I have no worries at all spinning my car to 6600. Its seen 7k a few times and hasn't cried yet.
Originally Posted by mr2guru
It's more rpm based than whp.
I'd feel more comfortable on boosted stock rods with 600whp at 6000rpm than h/c 450whp at 7200 rpms
if a heads cam ls1 is making 450rwhp @ 7200 rpms, something is definately wrong to begin with....
you know i did have a rod bend in my car but i had other problems with it too though. those rods saw 7k rpm daily and not one of the end caps let lose. i'd do rod bolts for extra security and probably leave it as is. not sure how i bent my rod because the piston wasnt tapped and i'm almost positive it didnt hydolock. the only thing i could think of was when i was testing my nitrous kit out and had the nos disconected.dumb move on my part.
so getting the motor refreshed with arp bolts, new bearings/rings, and forged pistons, would you guys feel comfortable with a heads/cam top end hitting a 150-200 shot and being spun to 6800?
should my lq4 build go smoothly, we'll see what the rods will take...i'm confident that an 11:1 lq4 with l92 heads, forged pistons, and MASSIVE cam on a progressive 300 shot won't break them. something will break, i'm just not sure what exactly..
