Crankshaft Pulley Position
Old 10-21-2006, 01:40 PM
jeanlucpicard's Avatar
Default Crankshaft Pulley Position
I am ready to pull the crankshaft pulley so I can move ahead with my heads / cam project but my Helms manual does not indicate there is a keeper pin or a specific position for the balancer / pulley to be placed back onto the crankshaft other than all the way on.
So, before I pull the pulley off is there a specific position to ensure the balance is right or do you just pull the pulley back on and torque it up?
Thanks for your time.
Old 10-21-2006, 05:43 PM
Krab's Avatar
No specific position the pulley should go on. Just seat it and torque the bolt down.
Old 10-21-2006, 05:46 PM
vettenuts's Avatar
The service manual is very specific on this, scribe the pulley and the crank snout prior to removal. Install in same position.
Old 10-21-2006, 06:30 PM
RrCoX22's Avatar
ya no need for correct balance... just anything you can get a bite on
just be careful when your torqueing it back down after install... those threads are prone to strip
