Will the G5X3 fit/work in AFR 205's?
I had to edit this as I found out this info on my set up..
My AFR 205's are milled to 62cc..
My A&A forged short block came w/ notched Diamond pistons 2-3 cc & valve reliefs..
So, basically thoughts on changing the existing cam 224/228 to the G5X3, or possibly something inbetween....
Super Hulk Smash
Originally Posted by 1998SuperSportCAMARO
find out what max lift is on those 205's. i know the 225's is at .600 with stock internals.
What are you talking about? The springs' max lift? I'm not sure what internals have to do with max spring lift. Also, lift has nothing to do with piston to valve clearance if that's what you're saying.
Anyway, the G5X3-114 has about .080" intake clearance with 59cc AFR 205s and the 112 has about .060" on average. So any AFR 205 head milled .042" or less will work (but I'd check if you mill it down any, and I suggest you mill to at least 62cc).
And yes, definitely get them milled. If you need to notch the pistons for valve clearance, especially with the larger valves, do it.
Originally Posted by YO-EL
Completely unaltered AFR 205's... Straight out of the box..
Will the G5X3@114 LSA work, with no other issues??
Everyone is always scared to flycut. I was. For no reason. I was scared of the cost. Well, it only ran me one old head, and $139 for the tool. And about 20min of cutting time. So basically, people are not milling heads and are spending money and not gaining max hp out of them because they are scared of the word "flycut". Ooooh. It's Halloween. I think I'll dress as the Isky Piston Notching tool.
That was worth a chuckle this morning....LOL
Can it fit and is it the right combination are two different things altogether (which has also been touched on many times before).
The X3 is fairly sizable and needs more static CR to be effective (as in mill the heads to 59-61 cc's depending on driving habits and available octane).
A smaller cammed set-up with milled heads will have way more "area under the curve" (more bottom end and midrange grunt) with similar peak numbers to the larger cam with lower compession. At that point WHY even install the bigger cam if that is the case?? To be reasonably effective the bigger cam needs more compression (which typically requires notched factory or aftermarket pistons)....THEN you can put up some big numbers and have decent midrange TQ as well. It is simply a much better overall package with the higher static (and ultimately dynamic) CR #'s.
The bigger the cam the more important increasing the static CR becomes....dont lose sight of that very important fact or your buddies car with a better thought out combination that has way more drivability and knocks down 5 more MPG will also leave you for dead at the dragstrip and thats no fun when your car is the one that sounds like a racecar...
Tony M.
...lots of guys are raving about the G5X3 w/ unmilled 205's....cars are running STRONG... track & street..
Let me repost:
Thanks..
Thanks..
I can't see where that'd be any problem whatsoever. But don't count on my word. Make sure to clay it just to be 100% sure.
I only cut .070" out of my pistons with 57cc 243 castings and 2.00" intake valves, and I am above the recommended .080" clearance (I have .083").
