do i have 7.79 dcr? please check in side
Old 10-24-2006, 08:50 PM
bad6as's Avatar
Default do i have 7.79 dcr? please check in side
227/231 lsk lobes 110+0 0.050
0.050
IVO 3.5
IVC 43.5
EVO 45.5
EVC 5.5
ECL 110
overlap 9
DCR 7.79
My mods are in my sig, i will have a ls6 im and ud pulley installed at the same time. Iwill be geting a 2nd car so this wont be a DD, but it will be driven maby 100 miles a week, when the wheather gets nicer again.
the heads will stay stock for a long while, and i would like to shift at 6500 due to the 98's rod bolts and also the fack its got over 93K on it.
i would like it to just be a monster at low rpm yet still pull as hard as the other cams that every one raves about the cams that have a great peak number but no TQ. and i would like this also to pull as hard up to as thoes cams, 233/239, 231,237, ms3
thanks
Old 10-24-2006, 10:51 PM
ArcticZ28's Avatar
What are the numbers at .006?
Old 10-25-2006, 12:43 AM
pdd
pdd's Avatar
i would make the cam intake biased so it will carry the power nice after peak hp. thats what im gonna do.
Old 10-25-2006, 12:58 AM
PREDATOR-Z's Avatar
Depends with which cc chambers, stock 110+4, milled 110+2 or +1
Old 10-25-2006, 04:42 PM
bad6as's Avatar
they are stock 98 heads
what would that peak at?
and what would be a good lsa and a good icl
Old 10-25-2006, 05:28 PM
bad6as's Avatar
277 153
281 156
Old 10-25-2006, 09:25 PM
Ryan02SS's Avatar
I got 7.91-1 Using standard LS1 specs with your cam specs you posted.
Old 10-25-2006, 11:07 PM
cws T/A's Avatar
Found some more compression .040'' cometic headgaskets
Old 10-26-2006, 07:44 PM
bad6as's Avatar
hua?
does a 110 lsa/icl sound ok or should i go with that 110+4
Old 10-26-2006, 08:37 PM
ArcticZ28's Avatar
I'd advance it if you're gonna drive it on the street to gain some more DCR and low end.
Old 10-27-2006, 03:45 PM
bad6as's Avatar
110 lsa with a 110 icl would put the power rage where?
110 lsa with a 108 icl?
110 lsa with a 106icl?
Old 10-28-2006, 03:58 PM
bad6as's Avatar
and about what hp and tq would i see from this?
