Thinking of getting a cam....
whats up guys, i have a 2001 ws6 a4. i have SLP LM, Cold Air Kit, Bellows, Belts, eibach prokit, and a diablo predator tune. i wanna get that loud rumble from a cam and the performance it gives. can u guys help me decide which way to go?? THanks!
Originally Posted by mvvette97
I just put a Comp 228/230 577/573 on a 112lsa. Here is a video of it.http://video.ls1tech.com/search/cam/...5a01735d55.htm
Maybe it is tuned and it was supposed to have a jacked up idle. If so, I apologize.
Originally Posted by N4cer
From watching the car hunting for idle at startup, it seems like the loping is more from lack of a tune than from the cam. A good loping cam lopes after the tune. Before the tune almost any cam should lope well.
thanks guys, but im completely clueless when it comes to internal mods, basically overall i have some boltons? What cam would u guys recommend to me with just those mods. The only other mods i may include r completing the exhast system. Will my diablo tuner come in handy after the install? But overall what should i go with for a bad *** idle and power gains...thanks
How was the power improvement with that cam? Sounds mean as hell
Sorry to say, your handheld tuner won't do much for you once you get a cam.
You can get a good loping idle from a shorter duration cam with the right amount of overlap. Many have had great success with the 224/228 cams ground on a 110 LSA. With your auto and stock heads, get it advanced at least 2 degrees, if not 4 and you'll like it. You'll need to replace the springs and pushrods at the same time, and you would be well advised to consider an LS6 Oil Pump and LS2 Timing set also.
