!oil Leak!
!oil Leak!
I've recently gotten this oil leak out of my 99 Firebird Formula. Of course I have the original LS1. Now I've smelt oil before but, I really noticed the leak today after my car started acting funny after a race last night. Well I lifted the car up a little higher from the front of the car. I noticed my Y-pipe had oil on it and that it was leaking from the rear of the engine and looked almost as if it was leaking from the tranny. Now the only things I can think of are a leaking rear seal, oil pan gasket, or loose oil pan bolts. I've ruled out a blown head gasket or leaking valve covers only because there was no visible oil on the fire wall. What do you guys think is the most likely source of my leak? and if anyone has been through this fill me in. Gracias!
I am replacing my rear seal today. The Felpro replacement came with a paper stating that the leak may not be from the seal but from the bolt holes themselves. It says that some one piece rear seal chevy motors where drilled and tapped too far by GM and the oil actually is coming through the flexplate bolt holes. I think this is my case because my flexplate bolt threads are covered in oil. Anyway, something to look at. Also, I am an LT1. Weither it is limited to this motor it did not say.
JD
JD
