View Poll Results: Which cam for cam only LS1
224/224 .581 112LSA
9
28.13%
232/236 .588 .575 114LSA
12
37.50%
Custom grind
11
34.38%
Voters: 32. You may not vote on this poll
Help me pick a cam for my cam only LS1
Old 10-27-2006, 07:44 PM
blazeone's Avatar
Default Help me pick a cam for my cam only LS1
'02 vette. Engine has stinger intake, Kooks 1-7/8" LT's w/high flow cats. Presently does 335rwhp.
My car is used as weekend street car, my last vette had a 224-581-112 LSA cam and I was happy with it.
On this car I considering going bigger. 232/236. .588/.575 - 114 LSA. Will I lose loads of low end?
Old 10-27-2006, 07:51 PM
DAVESS02's Avatar
I have a TR 227/224 114 for sale if you're interested. $225 + shipping. Just a few thousand miles on it.
Old 10-27-2006, 07:57 PM
BBADWS6's Avatar
I built a car with a cam similar to the second selection 232/236 and it runs like a scalded ape!!!! I put stock LS6 heads on it and the cam with a 112 centerline with 2 degrees advance ground in. Through a LS1 intake the car put down 394 RWHP.
I highly reccomend the larger of the two cams, it should be extremely drivable and should not have much noticable cam surge.
Old 10-27-2006, 07:59 PM
BriancWS6's Avatar
Don't forget about cams in between those, like a 228/230, 230/232, etc.
Old 10-27-2006, 09:23 PM
Asmodeus's Avatar
maybe go for something a little bit bigger.
try these 2 LSK lobes:
intake: #2131 243 .653"
exhaust: #2132 247 .656"
that'd be a 243/247 .653/.656, put it on a 111+1 or +2
the LSK lobes usually end up a little bigger than advertised though.
Old 10-27-2006, 09:36 PM
import slayer's Avatar
T-rex cam is the ****
Old 10-27-2006, 09:39 PM
blazeone's Avatar
You guys are so funny
Old 10-27-2006, 09:44 PM
cws T/A's Avatar
thats like putting a horsecock in a virgin .. itll never work
Old 10-27-2006, 09:59 PM
Asmodeus's Avatar
This is the internet.. ANYTHING is possible! (and I think there's already a video of that somewhere )
Old 10-27-2006, 10:09 PM
96ta's Avatar
HAHAHA
Old 10-27-2006, 10:12 PM
jamesSS's Avatar
i say TR 228
Old 10-27-2006, 10:54 PM
00TAProject's Avatar
233/239, That is the cam that I am really thinking about, maybe the MS3....
It's all up to wht you really want...Since it's a weekender then why not go for a large cam and a nice set of heads...Tune it out and have fun with it.
Old 10-27-2006, 11:45 PM
cws T/A's Avatar
Couple of Killer Cams under 46* IVC ABDC
228/232 .588''/.592'' 110+2 XE-R Lobes http://media.putfile.com/228232-110LSA-on-Startup
224/228 .637''/.639'' 110+2 LSK Lobes makes 8.1 dcr stock ls1 at 10.1 scr
236/242 .602''/.610'' 110+2 XE-R https://ls1tech.com/forums/dynamometer-results-comparisons/572811-dyno-results.html
235/240 .646''/.609'' 110+2 LSK/XE-R
235/240 .646''/.609'' 109+1 LSK/XE-R
Old 10-28-2006, 01:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
He is worried about losing low end power brotha. Wrong cam for this thread.
Why in the world are you guys telling him all these big *** cams?
I added the Custom section just to let people express and not be forced to choose 1 of the 2 cams listed. I think that you should look into a custom cam myself. Probably a lower 230's duration like 230/232 on a 114 so you have a wider spread of power and not a lot of lowend loss.
Old 10-28-2006, 07:51 AM
N4cer's Avatar
G5X2 on a 112.
Old 10-28-2006, 11:59 AM
austin21's Avatar
Originally Posted by N4cer
G5X2 on a 112.
thats what i have im satisfied with it and if thats not big enough for you then there is the g5x3 it should work
Old 10-28-2006, 12:04 PM
Rons 5.3's Avatar
Mines in my sig, sounds good and I'm happy with it. Ron
Old 10-28-2006, 01:16 PM
miami993c297's Avatar
You can consider this "228/230 0.639-0.592 @112LSA-112ICL LSK/XER" very seriously to reach your goals and match the best of both world, Daily driving and Performance driving in a single match according the last research of Patrick G.
- No flycut needed....
- PRC Platinium Dual Spring.... (works to .670 with LSK lobes)
- IVC is 46° @ 0.050, optimum LS1/LS6
- Only 5° of overlap @ 0.050 which gives a lot of mid range torque
Take a look there to find what you are looking for :
https://ls1tech.com/forums/lsx-parts-sale/598965-228-230-0-639-0-592-112lsa-112icl-lsk-xer-lobes.html
Christian
Old 10-28-2006, 01:35 PM
blazeone's Avatar
I'm now leaning towards the MTI X1 cam
Old 10-28-2006, 02:00 PM
Brianss1's Avatar
custom comp 228/236, 588/578,114,ported heads,all bolt ons,very satisfied with 393 rwhp,352 tq, on a mustang dyno with a stall converter and 12bolt.Dyno jet numbers would be more like 432/387.
Quick Reply: Help me pick a cam for my cam only LS1
