Thunder Racing ported LS6 oil pump or Melling?
I currently have the Thunder Racing modified pump which is a LS6 pump that is ported and blueprinted. I'm not sure if I should reuse it on my new motor or opt for the Melling oil pump that they sell. I'm unsure when more volume and pressure is needed. I will be building a naturally aspirated 415 ci motor. So should I keep what I have, buy a Melling, or something else? Thanks.
The extra volume isn't a big deal, but the extra pressure that shimming a pump will bring you'll want. 10psi/1000rpm is about what you want to shoot for, but it certainly doesnt hurt anything to have over that up until about 90+.
Jason
Jason
I reused my stock pump on my first cam swap way back when. Then on my 2nd cam swap, I opted for the Thunder Racing ported LS6 pump. I am now building a brand new engine from scratch and figured why not upgrade the pump while I'm there. There isn't a big cost difference between a pored LS6 and the Melling, but is it worth doing?
