f14 cam...too big for me?
Old 10-29-2006, 08:31 PM
Function>Form's Avatar
Default f14 cam...too big for me?
on futral's site it says that the cam is good for 3000-7500 rpm.. if i dont plan to buzz my car out past 6k is this cam too big to DD?
Phoenix 5.7's Avatar
all the aftermarket cams are 6k+. 6500 is safe still. if u have a problem spinnin that high, then something closer to a 220 or 224 might be better
Old 10-29-2006, 08:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You will hit peak long before that 7500. I know you are wanting this:
https://ls1tech.com/forums/lsx-parts-sale/600147-headers-cam-lid-hp-tuners-more-pics.html
I see all.....
Old 10-29-2006, 08:35 PM
thats what im thinking...its going to see a little spray and full bolt ons...so im not sure if its a little to big or not
yea...and if it can be used EFFECIANTLY on my car than i will be sending money tomorrow
Old 10-29-2006, 08:41 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Do it. A traditional split cam will be a decent daily driver. I vote you send money now. I like the F13-14 cams.
But what part of a cam is efficient?
Old 10-29-2006, 11:36 PM
Evans752's Avatar
Is your car a Auto or 6 Speed?
All these BIG CAMS with high lift and duration you have to go to 6000 to 6500 to get them to perform even the 405 HP ZO6 LS6 Vette motors. Good luck.
Old 10-30-2006, 05:58 AM
miami993c297's Avatar
Hi Function>Form,
If for any reason you look for a camshaft and a valve event that is absolutely great for a DD with a lot of torque, a wide torque curve and a strong pic of power around 6400rpm for the performance side (carrying the curve to 6900rpm easy) with certainly the maximum admissible overlap without any kind of surging when cruising at 1100 rpm or stuck in traffic, also still friendly manners and reasonnable mileage and not requiring to flycut your piston's head I have a :
228/230 .639-.592 @ 112 LSA +0 ... int LSK lobe / exh XE-R lobe to sell with his cam card from THUNDER
Let me know
Christian
PS: sorry for the long sentence, wanted to make it as accurate as possible
Old 10-30-2006, 06:01 AM
it is a 6 speed...
Old 10-30-2006, 08:35 AM
the Z06 didn't make 405 to the ground. they made closer to 370 if i remember right, and they also benifit from better heads.
Old 10-30-2006, 09:16 AM
Asmodeus's Avatar
If you don't want to spin past 6000, don't get a cam that peaks past 6000. Get one for high torque that peaks around 5900. I'm not as god as Predator or Patrick, but I would assume (following the trend I've noticed) that a 224/228 on a 108+2 would be pretty stout and meet your goals.
Old 10-30-2006, 10:24 AM
well i wouldnt mind spinning it to around 6500 which i heard these cams peak around 6300-6400...
it would be nice if anyone with this cam could chime in!
Old 10-30-2006, 10:39 AM
i searched google and came across where a guy put down 401/376 to the wheels with just lid/lt's/TD's.
and he didnt make power to 4500...
with ported tb,ls6 intake mani and good tuning would that help me see the cam make power earlier in the pull...
Old 10-30-2006, 10:42 AM
Ice Knight's Avatar
I'm definatlely not a cam expert...but if you had them make the lsa like...10+2 or somthing..that should make it kick in earlier...
I'm in the same situation...trying to make an f14 a little "torquier"..
I don't know if the lift would affect the tourqe much...in a good way..?
Old 10-30-2006, 10:48 AM
Did you read the stickies on the top, the best info I could understand about CAMSHAFTS are here:
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Thanks to the forum to educate us....
Old 10-30-2006, 11:08 AM
Is not it about Vave Events more than restrictively LSA??
in this case it seems that he wants an IVC between 42° and 44° at 0.050...
just take a look at the complete geometry and architecture if you want something fitting your desires.
Old 10-30-2006, 11:49 AM
Sigforty's Avatar
I daily drive the F14 in my Z06 every day. The cam peaked around 6600 rpms in my Z06 with Dart heads. I made 452 rwhp and 423 rwtq with the setup. It is not a bad cam to daily drive just make sure the tune is done well. The drivability of the cam all lies in the tune.
Old 10-30-2006, 03:17 PM
BryanJohnson's Avatar
i know of a F14 cut on 114 (plus 4 i think) that is in a bolt-on car only and a good HP tune made peak power at 6400 rpm, 3800 stall, and 3.73 gears. the guy daily drives his car about 30 miles a day in the city and loves it.
