Nice Set Up?
Old 10-30-2006, 07:16 AM
1BadTA13's Avatar
Default Nice Set Up?
how does this set up sound to you guys?
ThunderRace 230 Cam
Airflow Research Heads
Kooks Headers
Spec-4 Clutch
90mm Throttle Body
Fast Intake
my car is basically stock at the moment....one guy i talked to gave me this list-says its the best....any comments?????
Old 10-30-2006, 07:48 AM
SPLATT's Avatar
dump the spec for a textralia. and as far as the heads, if your on a fairly tight budget id say go with PRC LS6 heads from TSP. Awesome heads. If you do have the money the AFRs cant be beat. JMO though
Old 10-30-2006, 08:11 AM
TeEnAgE pHeNoM's Avatar
The fatest cam only car runs a Spec-4 clutch, so my question is why not? If it is good enough for his car it would probably be just as good for someone elses.
Old 10-30-2006, 08:13 AM
TOS98SS's Avatar
If you are going to go spec and you plan on driving on the street get the Spec 3+ and that is more than enough clutch for your setup .
And terminator heads are about 600 less also
Old 10-30-2006, 02:27 PM
SPLATT's Avatar
yes fastest cam only may be spec 4 but he isnt gonna be cam only, i would honestly say either or, both are very good clutches.
Old 10-30-2006, 04:02 PM
1BadTA13's Avatar
ok....would it be okay to just go w/ the cam...and no heads and possibly do the heads in the future?....also...is it nescessary to do the clutch, throttle body, and the intake???....what are my bare essentials here to do a cam?
Old 10-30-2006, 05:57 PM
PIMP_2's Avatar
I think FAST 90/90 setup is a bit over kill with cam only car
Old 10-31-2006, 08:13 PM
1BadTA13's Avatar
anyone else have an opinion?
