ARP crank bolt....what size wrench?
Old 11-03-2006, 06:31 AM
wavrdr's Avatar
Default ARP crank bolt....what size wrench?
Hey guys, I'm trying to turn my motor over by hand but seeing as I have a C5 I'm unable to utilize a socket/ratchet with the steering rack in place.
I can however use a wrench, yet I'm unable to remember the 12 point size needed??
Any help is appreciated!
Old 11-03-2006, 06:32 AM
slowride's Avatar
Mine is a 27mm I believe.
Old 11-03-2006, 06:34 AM
wavrdr's Avatar
The actual head of the bolt is 27mm huh? I didn't realize it was that big...I thought is was in the 24mm area....
Is it possible for anyone with an F-body to check for me?
TIA!
Old 11-03-2006, 08:00 AM
01formula6's Avatar
I know for sure I used a 24mm socket when I did my cam swap.
Old 11-03-2006, 08:49 AM
stealth71's Avatar
Stock bolt is 24mm so it is probably the same.
Old 11-03-2006, 09:10 AM
SLED28's Avatar
Should be 1 1/16 12 point
Old 11-03-2006, 09:15 AM
pewter 01 SS's Avatar
YUP YUP! +1
Old 11-03-2006, 10:40 AM
vettenuts's Avatar
A box wrench won't fit. I had to make one, I can send you a photo if you want, but basically I bought a socket, sliced it and welded it to a 1/8" flat bar. Then bent the bar to fit around the steering rack. Don't remember the size, but can check later.
Old 11-03-2006, 03:36 PM
JoeyGC5's Avatar
with above, cut 1/4" off the backside of the socket. Get a 19" long piece of flatbar (I like 1/4" thick, 2" wide as its stronger). Then mark 8"on the flat bar and bend to a 45 degree angle. Mark 3" from there and bend in the opposite direction at a 45 degree angle also. Then weld the socket to the edge of one of the 8" long ends, grind edges for clearance and you've got a crank tool.
On the 45 degree angles you can go a little more for extra room.
Old 11-03-2006, 03:49 PM
slowride's Avatar
1 1/16 and 27mm both work. Just used a box end 27mm for the engine I built. The box end has a slight angle on it that gives you enough contact to turn the engine over, but not for bolt removal/torque. Just curious as to what owning a f body has to do with it
TIA!
Old 11-03-2006, 03:50 PM
Joel_SS's Avatar
Correct, ARP bolt is not metric. I verified this with ARP when I installed thier crank bolt on my wifes 99 TA
Old 11-03-2006, 04:14 PM
wavrdr's Avatar
I don't believe that the steering shaft is in the way on F-bods whereas the Vette has the steering rack about an inch away thus causing a problem for simply removing bolt or turning the engine over...
Thanks for the help guys!
Old 11-03-2006, 04:21 PM
96-speed's Avatar
Yup - C5-ers hace to yank the rack to get to the bolt (with a socket).
Old 11-03-2006, 04:23 PM
exSSer's Avatar
What about an offset head wrench? I used one on my car with the stock bolt. They're kind of s-shaped. However, I used a 15/16" one on my factory bolt.(same as 24mm)
Old 11-03-2006, 05:55 PM
hpcubed's Avatar
The ARP bolt sticks out farther than the stock bolt so you can't get to it on a vette. You can turn the stock bolt with a wrench.
Old 11-03-2006, 06:23 PM
wavrdr's Avatar
No worries guys...I pulled the fuel pump relay/fuse and turn the car over...
I had a good feeling that the setup had plenty of room and I was right...
Please do not use this method if you have any thoughts of it being close!
Thanks for the replies though....you guys are the best!
Quick Reply: ARP crank bolt....what size wrench?
