EDELBROCK cam lobes for LSX
Old 11-04-2006, 09:47 AM
PREDATOR-Z's Avatar
Default EDELBROCK cam lobes for LSX
Just out of curiosity, are they proprietary or maybe CRANE?
Old 11-04-2006, 09:57 AM
JPH
JPH's Avatar
don't know about whose cores they use, but a company called EPW grinds 90% of there camshafts. there LS1 stuff isn't that aggresive from what I've seen. edelbrock has always been pretty conservitive on there cams.
Old 11-04-2006, 10:07 AM
PREDATOR-Z's Avatar
I was taking a walk through their site and I came across 2 cams offered for LSx.
I like their valve events though, well thought of BTW
2215- 220/224, .510/.510 111/108 LSA/ICL
2216- 230/237 .540/.540 110/106 LSA/ICL
slap a set of 1.8/1.85 on those and you have a bit more on the table.
I like the 2215, I bet with their 200cc heads it would make some decent power with a bit of tenderness on the valvetrain.
Add their carb intake setup with MSD ignition box and you have a decent street rod motor, easily in the 450/475 fhp range with no tuning guru needed.
Old 11-04-2006, 10:10 AM
BlackHawk T/A's Avatar
I agree a 1.8 rocker would be good there.
Old 11-04-2006, 10:50 AM
GuitsBoy's Avatar
With a 1.85 ratio rocker on there, the big cam might have a degree or so more at .050 and around .588 lift. Still kind of low for lift these days, but the ramp rates would be considerably more agressive than they were. Might make for a nice cam for someone who's already upgraded to a higher ratio rocker but now wants a cam.
Old 11-04-2006, 11:24 AM
hammertime's Avatar
What about the seat duration? Just seems really lazy compared to comp's stuff.
Old 11-04-2006, 02:27 PM
GuitsBoy's Avatar
seat duration would be the same. the higher ratio rockers will read .050 sooner though.
Old 11-04-2006, 03:35 PM
hammertime's Avatar
I understand the rocker ratio. What I'm asking about is the huge advertised duration numbers that edelbrock's cams have. I answered a question another forum member had in this thread but nobody responded. Since I know you guys know your stuff, maybe you can chime in...
Code:
            Adv. Dur.  |    .050 Dur.
P/N: 2215   300*   300*|  220*   224*   111 +3
P/N: 2216   314*   322*|  230*   237*   110 +4
I didn't bother putting in the VE's listed on their website, as they are in the PDF that I linked to, but they do look good at .050 lift. Those advertised durations are so much larger than I've seen, it just seems the ramps on those lobes must be really slow off and back onto the seat. Even Comps' mildest lobes are much shorter advertised.
Code:
        Adv. Dur.   | .050 Dur.  |  .200 Dur
lobe: 3767   274*   |     220*   |   134*
lobe: 3753   278*   |     224*   |   138*
lobe: 3713   273*   |     220*   |   138*
lobe: 3715   277*   |     224*   |   142*
lobe: 3720   269*   |     220*   |   143*
lobe: 3722   273*   |     224*   |   146*
The edelbrock lobes have anywhere from 26 to 31 degrees more duration for the same duration at .050". It would seem that would increase overlap (some), but it might also delay the intake valve closing point and bleed off cylinder pressure.
Any thoughts?
Old 11-04-2006, 06:52 PM
under pressure's Avatar
Default Edelbrock cam
Hammertime,
It was my thread you answered. Thanks. I have not gone further because I have hood clearance problems on the Toyota truck install. In fact the cam and intake are listed for sale in the Parts For Sale forum. I wish we could have tested the cam to answer some of these questions. Mac
Old 12-20-2007, 09:21 AM
blue66's Avatar
Bringing this back form the dead.......anybody have any experience with these?
