Help!!! cam degree
Help!!! cam degree
tring to set my dynamic compression ratio but dont know how to find Intake Closing Point (Degrees) ABDC @ 0.050 lift. dont have a cam card. not taking the heads off.
its a comp cam 240/248 112+4. grind 3730/3734 112+4.
bore 3.905
stroke 4
rod 6.125
piston dish -8.6
chamber cc 59
gasket thickness .052
gasket bore 4.0
deack height is -.005
installed cam straight up. car is dying up top and want to make sure my dynamic compression is good.
bore 3.905
stroke 4
rod 6.125
piston dish -8.6
chamber cc 59
gasket bore 4.0
