04 Escalade heads on 02 LS1?
Old 11-04-2006, 07:02 PM
SeriousPWRTRIP's Avatar
Default 04 Escalade heads on 02 LS1?
Just like the title says, I can get my hands on a set of 2004 Escalade 6.0L heads. Will they work on my 01 LS1? I'm completely illiterate when it comes to the internals of a motor. I want this to be a street/strip car with SICK all motor power. It is not a daily driver, but I would still like decent street manners for the occasional cruise. Also, if it will work, what Thunder cam would be good with it? The reason I want Thunder is because I currently have a Thunder 224/224 on a 114 that has never been installed and am going to try to swap it out for a different cam. I would like to run 3.73 gears and stick with a 26 inch tire. I currently have MAC mid-length headers and no internal engine work. Any help would be great!
Old 11-04-2006, 07:05 PM
Ls2Sonoma's Avatar
they will lower your compression ratio
they will work, but you dont want them. i can use them.... =]
Old 11-04-2006, 07:12 PM
i realize it will lower compression, but is there any way to counter that and make serious power? Im shooting for around 450 NA. A friend of mine has them and I know he will hook me up, just want to have a plan together before I throw money away like that.
Old 11-04-2006, 08:56 PM
MiaSSmaro98's Avatar
sell them ang get a pair of 243 ls6 heads
Old 11-04-2006, 09:36 PM
Beast96Z's Avatar
Yea, a 6.0 casting by itself is not going to be a power house head. By the time you mill the head down enough to get the compression up, you won't have much P/V clearence. You should start looking for the 243 heads if you want a nice stock, bolt-on casting.
Old 11-05-2006, 12:07 AM
alright, that answers my question.. thanks guys! Looks like I'll be sticking with my original plan of either AFR or Trickflow heads and trying to find a cam to match. My goal is just a 450-500 rwhp NA car that can be driven anywhere. Any suggestions are welcome!
Old 11-05-2006, 12:23 AM
02ws6badbird's Avatar
nthat
Old 11-05-2006, 02:02 AM
Ls2Sonoma's Avatar
how much for those 6.0 heads?
Old 11-05-2006, 10:28 AM
Beast96Z's Avatar
For that power range, you'll deffinatlly need a nice ported casting like the ones you mentioned.
Old 11-05-2006, 05:21 PM
i'll have to ask him... he might keep them if i dont want them, hes just trying to get me to actually start working on my car and waving them in my face! i'll see what he says tomorrow.
Old 11-05-2006, 05:43 PM
My goal for the car is a daily driveable, 450 rwhp car with a mean *** cam lope. I just need to find out how I can achieve that, so I can start buying the parts as I get the money. Are there any sponsors on here that give good advice and have the patience enough to explain something to somebody like me that doesnt know exactly what I need? I realize that other mods are necessary to handle the power, but I already have the transmission and rear end covered. The fuel system is the only thing I am worried about. Any suggestions would be awesome!
Old 11-05-2006, 09:02 PM
Asmodeus's Avatar
Hmm.. are those the L92 heads? Will those fit on a 3.9 bore?
Old 11-05-2006, 09:15 PM
i have no clue what they are... thats why i asked on here. I havent seen the heads yet and dont know what they will fit.
Old 11-05-2006, 10:05 PM
Asmodeus's Avatar
Yeah I just went into the L92 stick and found it..
https://ls1tech.com/forums/showthrea...9&page=3&pp=30
post #64, these heads need at least a 4 inch bore to work.. need a 6.0 liter truck block or LS2 block.
Old 11-05-2006, 11:14 PM
alrighty, well that answers that.... anybody got any suggestions for a 450 rwhp set up? Would a T-Rex cam and the TSP Stage 1 LS6 heads do it?
Old 11-06-2006, 01:51 PM
hmm, anybody?
Old 11-06-2006, 04:34 PM
Asmodeus's Avatar
probably would as long as the ring seal etc is up to par. You can find a lot of H/C cars, their power and their setup, in the dyno section should give you real results with a few different combos.
Old 11-06-2006, 06:20 PM
thanks! search button hasnt been working for me until just a little while ago, so i guess i need to start trying to find what im looking for
