Highest compression with...
Old 11-05-2006, 02:11 PM
BlackHawk T/A's Avatar
Default Highest compression with...
Stock pistons? Without changing the bottom end, how high can you get your compression with heads/cam/gaskets?
Want to take advantage of an E85 setup next year
Old 11-05-2006, 02:53 PM
Kraest's Avatar
14:1?
If you get a head with a small enough chamber, anything is possible.
Old 11-05-2006, 09:22 PM
Without ruining quench and getting a real nice DCR I think it would be a great setup for E85's high octane. I didn't think you could get much higher than 12:1 SCR with a 59cc head without changing pistons?
What kind of numbers could you get away with on a 105 octane fuel anyway?
Old 11-06-2006, 08:30 PM
Bump.
Old 11-06-2006, 09:02 PM
Gm-LSX's Avatar
Answer is in here: https://ls1tech.com/forums/generation-iv-internal-engine/599321-there-47cc-heads-other-ways-get-close-12-1-cr-5-3-a.html
Wich means the 14:1 is for 325 CI engine. Hm..... that's close to diesel setups. All alluminum diesel engines are unknown to me. Makes me kind of worry.
Old 11-06-2006, 09:33 PM
Didn't really answer my question, i'm wondering what kind of SCR and DCR I could run on E85?
