Bent Pushrods Messed Up Heads Pics
Old 11-05-2006, 06:51 PM
T-REZ's Avatar
Default Bent Pushrods Messed Up Heads Pics
can my cuz just put in new pushrods or does he need new heads.
thanks for any help
Attached Thumbnails Bent Pushrods Messed Up Heads Pics-ls1-tt.jpg   Bent Pushrods Messed Up Heads Pics-ls1yy.jpg
Old 11-05-2006, 07:04 PM
slow trap's Avatar
that looks bad but if the valves are not bent i don't see why he can't just put some good p-rods in.how long did he run it like that ? i would definitely change the oil also.
Old 11-05-2006, 07:06 PM
T-REZ's Avatar
thanks for the input,he did not run it that long
Old 11-05-2006, 10:25 PM
T-REZ's Avatar
anybody else
Old 11-06-2006, 12:07 AM
Slo_240sx's Avatar
It should be okay. As long as it didnt collapse a lifter or hurt the rocker or valve you be in the clear. That part of the head really isnt surrounded by anything important, and underneath is just a big void for the lifters. Good engineering, but its a bitch to change lifters. Get HARDENED pushrods and it wont happen again as long as you dont over rev. Make sure you get the right length.
Old 11-06-2006, 01:56 AM
T-REZ's Avatar
Old 11-06-2006, 05:23 AM
vettenuts's Avatar
Guess I am missing somthing, what is wrong with the head? I can't see anything.
Old 11-06-2006, 05:32 AM
rollinna65's Avatar
Same thing happened in my buddy's car. We just swapped out the stock pushrods with some from comp cams and changed the oil. After that she ran great.
Old 11-06-2006, 06:27 AM
Bandit28's Avatar
I didnt see any damage on the pics what is it that i would be looking for
Old 11-06-2006, 07:14 AM
V6 Bird's Avatar
The enlarged pushrod hole maybe
Old 11-06-2006, 07:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You could fit 1 1/2 pushrods in that one hole....Geez. Looks like some valve train geometry was a hair off somewhere.
Old 11-06-2006, 09:52 AM
Slo_240sx's Avatar
Change the oil too!
Old 11-06-2006, 10:02 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Slo_240sx
Change the oil too!
Unless he is running molassess that is the least of his problems.
Old 11-06-2006, 10:44 AM
Krab's Avatar
Looks like one of my pushrod holes after I missed 3rd. As others already said, it should be fine as long as none of the valves are bent. Have your cousin do a compression test and if all the cylinders check out, drop in the new pushrods.
Old 11-06-2006, 11:07 AM
muncie21's Avatar
Unless you've got a crazy cam in there, I'd just put stock PRs back in. They are much easier to change (cost and time) than valves.
Old 11-06-2006, 11:14 AM
slt200mph's Avatar
You can buy real push rods from texas speed and other vendors for around
$100..dont waste your money on OEM crap..
Old 11-06-2006, 12:27 PM
cjs27410's Avatar
I agree.
I've seen this problem posted before. Do some searches. Valve train geometry is the first place to look. You need to identify the problem before installing any new parts. My ls1 has push rod guides does yours?
Old 11-06-2006, 12:37 PM
slt200mph's Avatar
Over revving the engine has nothing to do with the geometry...wish I had a dollar for every ls1 bent push rod I've seen
Old 11-06-2006, 12:49 PM
cjs27410's Avatar
Over revving was not mentioned by the original poster.
Old 11-06-2006, 12:52 PM
slt200mph's Avatar
You don't need to hire Sherlock Holmes to figure it out
