Injectors with New heads
Old 11-07-2006, 12:59 PM
sdbrown84's Avatar
Default Injectors with New heads
I am doing a Head Swap in about a week. Car has a 224/228 cam (see Sig).
Question is do you need a new set of injectors with a H/C car or will the stockers hold up?
I am getting a dyno tune with the setup as well.
Old 11-07-2006, 01:03 PM
Cam02ss's Avatar
once i went to heads i had a racetronix fuel pump and 37# injectors put in. when i just had a cam (230/236) i was ok but the stock injectors were maxed out. what heads are you getting and are you going to a different cam?
Old 11-07-2006, 03:58 PM
sdbrown84's Avatar
Same cam but TSP LS6 stage 2.5 heads.
Old 11-07-2006, 04:22 PM
Long Beach's Avatar
Im going with almost the same thing, i would also like to know if my stock injectiors and fuel pump will be fine.
Old 11-07-2006, 04:45 PM
Cam02ss's Avatar
if you're going to be throwing even more fuel to it i would do a pump and injectors. that way if you guys do end up getting different cams it will be out of the way
Old 11-07-2006, 05:22 PM
sdbrown84's Avatar
Which injectors would you recommend?
Brand and #
