T1 & 1.8 rockers
T1 & 1.8 rockers
Would the springs that come with the T1 package be ok to use with the Comp 1.8 rocker arms? Or do the 1.8's not add enough lift to make a difference.
Thanks
Alan
Thanks
Alan
Re: T1 & 1.8 rockers
your lift would be .590
IMO, I would only use dual springs for that much lift. Then you definitely have to check for piston to valve clearance. I wouldn't even attempt with the hassle if I were you. <img src="images/icons/smile.gif" border="0">
later,
Steve
later,
Steve
