Oil pump recommendations?
Old 11-09-2006, 01:20 PM
11Second Club
Gauge's Avatar
Default Oil pump recommendations?
I've searched around, and I haven't found many posts concerning what oil pumps to get. Mellings? SLP? Plain Jane LS6? Other? I'd create a poll, but I'm sure there are a zillion out there that I'm not familiar with.
Old 11-09-2006, 01:39 PM
FIEROPHREK's Avatar
Exclamation
From my understanding the stock LS4 pump is a high volume high pressure pump. It uses pressurized oil to operate the D.O.D. function of the engine. I'm not sure what operating pressure and volume it will be able to work to , but it's gotta be better than a stock LS1.
Old 11-09-2006, 03:35 PM
11Second Club
Gauge's Avatar
Anyone else? I'm inclined to buy the SLP pump, but I'd hate to buy something without seeing at least some feedback on it.
Old 11-09-2006, 03:51 PM
SOMSS's Avatar
I have the SLP ported LS6 oil pump. It works great and is reasonably priced.
Old 11-09-2006, 04:29 PM
Killer_Bluebird's Avatar
Got TSP ported pump and it works great and was priced better than the SLP.
Old 11-09-2006, 04:35 PM
2001bluerata's Avatar
I 2nd the TSP ported LS6 oil pump, I have it, has great oil psi. Warmed up engine I sit at about 45psi.
Old 11-14-2006, 09:31 PM
shoemike's Avatar
get the melling its the same price
Old 11-14-2006, 10:54 PM
2000Hawk's Avatar
Just installed the TSP Ported LS6 this weekend. Real good price too.
-Joel
Old 11-15-2006, 09:56 AM
98Camarod's Avatar
i thought ported oil pumps only flowed more oil and not increased oil pressure. Shims increase oil pressure right?
Old 11-15-2006, 11:17 AM
JPH
JPH's Avatar
Melling #10296 Oil Pump. High Volume(15% More) High Pressure(50psi+ At Idle Hot), I Use These Pumps All The Time, And They Are By Far The Best Ls Pumps Out There Right Now. But I Strongly Recomend If You Get One, Change The Releif Spring Out To The Blue Color One. It Gives You This Spring Option In The Box When You Purchase One. The Blue Spring Is 40psi Hot At Idle, And Around 65-70psi Wot. Hope This Helps. They Cost Around $140
