ET 225cc heads + adjustable Comp Rockers = new pushrods
We had orginally setup the ETP 225s with the stand for the factory rocker and measured pushrod length @ 0 lash and added preload. Pushrods were made and we put a couple thousand miles on the car. We picked up a set of the Comp Chromoly adjustable rockers and finally got around to checking the length and geometry. The intake rockers hit the center of the valve tip with a 8.100 pushrod while the exhaust took a 8.150 to center the wear pattern on the tip. I ordered a set of Trend 3/8" .135 wall pushrods from Jason @ Texas Speed and hopefully should have some track results next week.
