rocker removal
Old 11-11-2006, 01:16 AM
BigDB's Avatar
Default rocker removal
im doin alot of work on my car while my tranny is being built, one thing is checking my pushrods and changing my valve seals. I need to remove my rockers but dont want to just start taking the bolts out. My question is do I need to put the cylinder im working on to TDC?
Old 11-11-2006, 01:52 AM
mvvette97's Avatar
taking the rockers off doesn't matter but you want to have whatever piston you are working on to be up so your valve won't fall. I'll give you some advice, Get the Crane valve compressor tool. It's money well spent
Old 11-11-2006, 12:37 PM
BigDB's Avatar
ya i know that when im removing the locks from the prings to have that piston at TDC, but wasnt sure about the rockers since a few are inbetween open/close events
Old 11-11-2006, 10:18 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
just loosen the bolts
Old 11-11-2006, 11:57 PM
heavymetals's Avatar
The only concern in regards to removing rockers that are between TDC is the extra stress it puts on the threads.
If you have the plugs out, it doesn't take that much effort to turn it to a position that puts a minimum of load on the threads once you loosen it.
My $0.02
Old 11-12-2006, 12:26 AM
BigDB's Avatar
well i got em out with no problems, and good news my push rods werent bent. they are 7.400 in length is that right? im using stock rockers and a F13 cam
Old 11-12-2006, 02:22 AM
1stz06's Avatar
My advice is to get a push rod rod length checker $20 from sponser. The 7.4 are probably fine but you will be amazed how quite your valvetrain will be with the proper length. Send me a PM if you want more info on using the PR length checker.
J.R.
