Anyone have a proven PCV system
well, if you go with a breather, all that oil that was going in you intake will now go in your breather, and eventaully blow a film of oil out under your hood. That is unless you clean it regularly...
I think i am going to try that 75$ catch can that is floating around in one of these threads...
I've deleted mine as of yesterday. I have a LS6 valley, AMW catch can, and a Metco and still get oil in the intake. New setup has the valve covers connected, LS6 valley connected to the valve cover where the fresh air line was, and a metco on the passenger side. I'll beat on it this weekend and see how it does.
Originally Posted by ls1408cp
Showoff, If only us vette guys could be so lucky
Phil I've tried every possible combination, except use of the vacuum pump. Did you vac pump setup not turn out well?
Originally Posted by Phil99vette
My vac setup works well, looking for solutions for cars without vac pumps.
