what heads work best with t-rex cam?
Performed great for my little Forged 348ci. Managed 453rwhp on 93 octane with only 500 miles on the new motor, on a Superflow dyno. I have the TREX V2 and a set of older Lingenfelter heads I got for $150 bucks off a user on here. They are 853 castings, CNC ported and milled quite a lot. According to LPE, when these heads were ported back in 2000, they flowed 289 cfm at .600 lift, which was really good back then, but by standards today, a little low. Any set of CNC heads that flow around or over 300 cfm will make you some very nice numbers with the TREX. It is ground to be a max effort cam for stock heads, but works just as good or better with ported heads than any other cam out on the market.
Originally Posted by prostock_bigblock
I would go with stage1 PRC ls6 heads. should fit without flycutting.(correct me if wrong about P/V)
