heads for turbo
if your motor is still stock alot of people put the 317 casting heads on a stock shortblock since they will lower the compression.the ls6 heads flow better but they don't have larger combustion chambers.
Originally Posted by fstls1camaro
if i put ls6 heads on my car could i still go turbo.
317 is the way to go, I am hand porting my own set and will put it on a flow bench, I will post results very soon early DEC when I put all the turbo parts together.
We can do you a set of 035 casting (same as 317), with 72cc chambers to lower compression, Ferrea 6000 series stainless valves, bronze guides, Patriot Gold Dual springs, ti retainers, etc. for $1295.00 per pair assembled. If have any questions, just let us know.
LS1Tech Premium Sponsor
I think the question we should all be asking you is are you planning on installing the heads & then adding boost later? The 6.0l heads would be doggy without boost, I had to do that for about a week & it was pretty crappy.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
