afr 205 gasket question
i have afr 205's milled to 59cc by lg motorsports, we had them decked .003 (as they came off a car that blew a piston.) they look great now, and are about to go on the car. we are fly cutting the pistons as well. my questions are:
what gaskets to use? (stock bottom end with g5x3 cam)
are stock length pushrods right? or do i need another length?
anything else i should be considering?
btw, these are going in a 2004 gto
1 Post
I would think you need a shorter pushrod, you might want to call LG and ask them what length. I have heard that your geometry will be off if heads are milled and you use stock pushrods. The cam you are using probably has a smaller circle also, but I am not sure.
