custom cam-here i come-Comp XE-R 228-232 111+1
Old 11-17-2006, 01:12 AM
pdd
pdd's Avatar
Default custom cam-here i come-Comp XE-R 228-232 111+1
after 5 cams- i'm finally gonna try a custom cam-comp XE-R 228-232 111+1. 11.31scr & 8.72dcr wit my current setup. i wanna hit 450rwhp through my 4.10's, 6sp and at least 400rwtq.
Old 11-17-2006, 02:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Weren't you really close on your last cam?
Old 11-17-2006, 02:49 AM
pdd
pdd's Avatar
yes 440rwhp 393rwtq im also getting my stock rockers back on
Old 11-17-2006, 03:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What kind of lift is on that cam? .630+?
Old 11-17-2006, 06:05 AM
pdd
pdd's Avatar
i forgot exact but right around .585 .595, i didnt want the lsk lobs. my reason for change is because i was leaving power on the table. i hope with the the new setup, ill leave nothing on the table
Old 11-17-2006, 06:08 AM
SideStep's Avatar
Cool.. when r u going to have results....
Old 11-17-2006, 06:09 AM
pdd
pdd's Avatar
ill be installing soon as my cam gets here, but no dyno probably till spring i even got me the sportsman degree wheel so it fits with the motor in the car
Old 11-17-2006, 07:11 PM
02SOMWS6's Avatar
I don't get it. I have a smaller cam with a set of ported 241 heads with a 12 bolt rear that has 4.30 gears and a Denny's nitrous ready driveshaft and my car put down 452rwhp and 408rwtq. You have what should be a better set of heads and a bigger better cam and I think Don tuned both of our cars and if he did then we both dynoed on the same machine. I think you should be making way more than me. I also have a set of Harland Sharp rockers.
Old 11-17-2006, 09:19 PM
WeathermanShawn's Avatar
I think you'll make it! Best of luck.
Should make that 400TQ+ reading easy.. Let us know..
Old 11-18-2006, 04:32 AM
pdd
pdd's Avatar
well i didnt degree my cam in and didnt have the optimun valve events or head gaskit. so ya yr right, i should of made more, but i didnt get everything right this time i hope to get everything perfect. but of course i get my cam in and its 229.2 232.5 111.4 lsa instead of 228 232 111, so valve events are off and dcr suffers a bit but im still hoping for 450rwhp
Old 11-18-2006, 12:46 PM
Black02SS's Avatar
Nice to see you are still going after your goal. Keep us posted as I like to see your results. I am working on a combo that is pretty similar to yours but with a larger cam. I too am hoping for over 450/400.
Old 11-18-2006, 02:55 PM
02SOMWS6's Avatar
thats still bigger than my little 224/228 110lsa 581/588 baby cam
