Futral F13 / F14 or similar custom cam, help please...
Old 11-17-2006, 08:47 PM
Ice Knight's Avatar
Question Futral F13 / F14 or similar custom cam, help please...
Time to add to the "Cam help" pile of threads... (sorry )
Anyways...I was originally interested in an F14, I like it's overall relative size, but after reading Patrick G's torque thread, I think I'd like something with a bit better torque curve...while retaining a beastly mid/high end pull
So...that leads me on to this question...What would you *smart cam enthusiests* recommend for a car with the current mods in my sig, (plus an underdrive pulley during the cam install) and a couple other small bolt ons...like a "professionally" ported throttle body, LS6 intake...
I think what I'm aiming for would be something in the low 230's, and lift around 600...I'm not afraid of lope...in fact.. it is encouraged
Keep in mind it must retain good(ish) overall street manner's and will primarily be a daily driver... (most of the time) and I don't want to have to have to rev it too high...
Would a lower LSA help with the torque a bit?...like maybe 108, or 110, or whatever...and what lobes would be good too? I don't want anything too incrdibly harsh on the springs...
Thanks in advance
*Not me
Old 11-17-2006, 11:08 PM
LSUxBlake's Avatar
Ever considered the F11?
I had one that made real nice power on the street. Keep in mind this is with heads, but you can see that it has a pretty healthy torque curve.
Old 11-18-2006, 01:12 AM
BLASTER's Avatar
My F13 produced pretty good results. I did alot of reserarch before I bought it as I wanted the same characteristics as you did.
do a search on my name and your get my dyno sheet...good luck
Old 11-18-2006, 11:09 AM
Checkmate's Avatar
I was looking for the same results and went with f13 112lsa. I was very pleased with the results.
Old 11-18-2006, 12:16 PM
PREDATOR-Z's Avatar
228/232, .588/.595 110+2
That fits your needs
Old 11-18-2006, 03:29 PM
1999 SS's Avatar
i just switched from a comp cams cam with the same duration and lift but on a 112lsa to an f14 and actually prefer the new cam to the older one. they idle about the same and torque comes on earlier and the cam feels more linear than the comp cams unit but i also added an fast/nw 90mm combo and 4" exhaust at the same time.
Old 11-18-2006, 03:30 PM
1999 SS's Avatar
i live in clinton twp. too, where do you live in clinton twp?
Old 11-18-2006, 05:56 PM
SSNISTR's Avatar
If you want a really nice, streetable cam, with a nice TQ curve....get a F11-112.
It was a hasle and a half getting mine right (long story) but all in all it was worth it.
Old 11-19-2006, 04:49 AM
PREDATOR-Z's Avatar
Do you guys even read what he is asking for? (Not reving too high)
Same cam different LSA/ICL will behave differently, and how can you compare a cam, against another + 90/90?
If the FM14 112 makes more trq and earlier than the specs I gave, I'll eat my........
Old 12-19-2006, 11:21 AM
Ice Knight's Avatar
If i went with a cam with these specs how would it work with heads if down the road I somehow could afford to do that? As it is I just plan on ported TB and a pulley to go with what I have now, maybe a LS6 intake sometime.
Old 12-19-2006, 01:04 PM
Sigforty's Avatar
The torque curve on my F14 is very good. It made 423 rwtq with Dart heads and cam only did 408 rwtq. I so not see many other cams out there that make more torque than Futral's. I would post up the graph but the site that is hosting it is down. If you also check out the F14 high lift numbers they make more torque than the standard F14.
Old 12-19-2006, 04:50 PM
ez98ls1's Avatar
What would this cam be like with the AFR 205's or the TEA 5.3 stage 2's?
Old 12-19-2006, 05:37 PM
pdd
pdd's Avatar
Originally Posted by ez98ls1
What would this cam be like with the AFR 205's ?
my cam is a 228 232 111+1 and i have afr205's 61cc. im hoping for 450rwhp + and 415rwtq +
Old 12-19-2006, 08:09 PM
algws6's Avatar
when are you expecting some numbers?
Old 12-23-2006, 01:28 PM
streetlegalls1's Avatar
Don't get in a rush,go to the local tracks and events and talk to people,check out their rides and listen to the cars.Don't hesitate to call Futral-[they do answer the calls]-,LG motor sports,Thunder Racing,etc.,some of our needs may seem similar but these companys make their living at this,and yes some may be bias;and when they are,hang up and make the next call,you will find the answer your seeking.Remember to take your time...
Old 12-23-2006, 02:55 PM
pdd
pdd's Avatar
spring
Old 12-23-2006, 05:17 PM
Hype's Avatar
How much overlap does that have? 6 or 10? or am I completely off basis haha
Old 12-23-2006, 07:52 PM
ToplessTexan's Avatar
10 @ 0.050 (assuming XE-R 3724/3726).
Old 12-24-2006, 02:27 AM
PREDATOR-Z's Avatar
It has more overlap than a FM14 on a 112 (233-224=9*)
While the 228/232 110 has 10* andd if XE-R is not enough you can grind it on a |LSK/XE-R| combo and that would be lethal.
228/232, .639/.600 110+2
Old 12-25-2006, 08:18 PM
bad6as's Avatar
sorry to bring up the dead but this area or grind seams to be the best for cars who dont want a high shift point.
predator-z you said that 228-232 on lsk/xer 110+2 would be leatheal. would any hp or tq be gained from lsk lobes on the intake and the exhaust as well?
Quick Reply: Futral F13 / F14 or similar custom cam, help please...
