teflon sealant for temp sensor
Old 11-18-2006, 11:58 PM
pHEnomIC's Avatar
Default teflon sealant for temp sensor
I drilled and tapped the one piece above my oil filter for a temperature sensor sending unit.
It is 1/8'' npt, should I use teflon tape or loctite on this? I dont want it leaking oil. My friend tapped it for me and did a great job but im worried the teflon will fall apart from the oil.
Old 11-19-2006, 12:14 AM
Ferocity02's Avatar
Teflon tape will work just fine.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Teflon = kick ***/leak proof.
Quick Reply: teflon sealant for temp sensor
