Will the pan come off?
Well I was changing my cam, all went well until i changed my oil pump. I accidentally dropped the pickup tube bolt and my wrench into the pan. I tried to get them out with a strong magnet on a piece of metal but both fell deeper. I think the only option is dropping the pan.
Since my bolts are almost already all the way off, can i just remove them the resst of the way and pull the pan out, or is this impossible without pulling out the engine or anything else?
When I bought my car the pan had a hairline crack in it. I was able to get it out by removing the motor mount bolts hoisting up the engine as far as it goes, and losening up the cradle bolts to drop the cradle about 2 inches. Its still a P.I.L.A. I would try droping the pan as far as you can the see if you can get your hand down in there. Just my .02 Hope this helps.
Whatever you decided, don't leave that crap in there. Best bet would be to pull the motor. When you figure in all the time it takes to lift the body, drop the k-member a couple inches and hoist the motor you might as well just lift the body off the k member completely and put the engine on a stand. While its out replace the rod bolts and get a new gasket for the pan. I can guarantee you'll get a bad oil leak if you try doing everything with the motor in the car.
you dont need to pull the hole motor apart, but you are going to have to pull the motor up with a cherry pckr so you can take off the oil pan. i wouldnt leave anything in there if i were you. besides you just need to pick up the motor a few inches, it wont take long either.
unbolt the motor mounts and lift the motor as high as u can get it and drop the pan down onto the k member. I dropped two lifters down into my pan. go invest in some pen magnets and fish them out through the front. you might have to take your radiator out so u can sit up and look thru the front. dont leave that **** in there!
Why would anyone leave a bolt in their oil pan? If that gets caught in anything, it would mean death of the engine easily.
I ended buying a magnetic pickup tool and luckily it did the trick even though ive never had good luck with them. I pulled the wrench and bolt out within seconds, I was surprised. I ended up dropping that bolt at least 10 more times before finally getting it in. I hope to god i didnt pinch that o-ring (it looked line up the last time i saw it before tightening down so i think i should be good).
good luck getting it finished up Jon, are you going to be tuning it yourself, or getting it done?...i know a certain sponsor on our other board with a mustang dyno
