need advice: cut in cylinder wall
Old 11-20-2006, 01:00 PM
yak
yak's Avatar
Default need advice: cut in cylinder wall
So somehow there are 2 cuts in my #8 cylinder wall. they are about 1/3 inch long and about .010 deep. my fingernail will catch on them. Is the block now junk? the edges are not rough. I am having a really bad day.
Old 11-20-2006, 01:21 PM
Matt2105's Avatar
I believe the max you can bore an LS1 aluminum block is .010. So I wouldnt call it junk. If it can be machined then you are in good shape. If not, I think you can still sleeve it.
Old 11-20-2006, 01:32 PM
DarinsTA's Avatar
are they vertical or horizontal?
Old 11-20-2006, 01:35 PM
yak
yak's Avatar
horizontal one scuff is only about .005 but the other is between .010 and .015
Old 11-20-2006, 03:19 PM
66deuce's Avatar
the most you can hone a 98 block is about .004-.005.
