Questions about compression ratio... (search not working)
Old 11-20-2006, 02:27 PM
11Second Club
Gauge's Avatar
Default Questions about compression ratio... (search not working)
I'm trying to calculate exactly what my compression ratio will be in different situations. I just disassembled my 100% stock LS1 shortblock. I'm using this calculator, and I'm not sure of the numbers it's giving me.
With all the default values the calculator says 10.0:1. Isn't the LS1 10.3:1 stock? Where are these values wrong? I was pretty sure that an '02 had .054" head gaskets where they have .055" entered. Also, I thought the combustion chamber on the LS1 heads was 66.67cc, not 67cc. Are these right? Are there any other inaccuracies in the default values here? All I'm changing is piston dish size, gasket thickness, and combustion chamber.
Thanks in advance, everyone.
Old 11-20-2006, 04:45 PM
JPH
JPH's Avatar
change you deck height to -.007, and see what happens then. and .054 is gasket thickness.
Old 11-20-2006, 07:10 PM
11Second Club
Gauge's Avatar
Deck height will not accept a negative value. When the piston comes out of the bore, is that negative or positive?
Old 11-20-2006, 09:06 PM
Randy WS6's Avatar
Try this ,It might help
http://www.c5frc.com/calculators/Com...Calculator.htm
Old 11-20-2006, 09:21 PM
11Second Club
Gauge's Avatar
Originally Posted by Randy WS6
That's the calculator that I was already using. It's saying 10.0:1 CR with the default values. Isn't a stock LS1 10.3:1? If so, which of these default values is wrong? Or is the calculator itself wrong?
Old 11-21-2006, 09:05 AM
GuitsBoy's Avatar
Try this one:
http://kb-silvolite.com/calc.php?action=comp
Old 11-21-2006, 10:10 AM
JPH
JPH's Avatar
yes use the kb-silvolite.com calculator, that's the one i use also. you can use -/+ numbers. piston out of deck means (-).
Old 11-21-2006, 10:23 AM
N4cer's Avatar
If I'm not mistaken, the gaskets are like this:
GM MLS: .060"
GM Composite: .054"
Old 11-21-2006, 10:44 AM
383Z4ME's Avatar
Default calculator
http://members.uia.net/pkelley2/DynamicCR.htmlis a good article about the different factors involved with links to a calculator
http://members.uia.net/pkelley2/dcrvb6.zip is a downloadable link for the calculator only
