What to buy?
Old 11-20-2006, 08:53 PM
m1candelaa1's Avatar
Default What to buy?
I have a 99 ls1 TA M6,i have exactly $2000 to spend on performance what do you recomend i spend it on.I would like a new K frame and LT headers,...
Old 11-21-2006, 09:28 AM
GuitsBoy's Avatar
Why a new K member? That a lot of money for not much if any perceptible gain. Thats usually one of the last mods anyone does.
Id do something on the order of:
$100 - Air Lid
$450 - Long Tube headers
$450 - Duals or catback
$400 - cam
$250 - springs
$100 - pushrods
$150 - misc gaskets and fluids
Depending on what you want out of the cam, this could get you to the 375 - 400 RWHP range.
Old 11-22-2006, 12:34 AM
I figuire a K frame for easyer install and weight savings, i also have to replace my rack & pinion.Its leaking.If i get a cam dont i have to reprogram my computer/dont know how or where to do that were i live.
Old 11-22-2006, 01:40 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I did it close to the first. Suspension, then bolt ons.
Old 11-22-2006, 01:42 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You will probably need some sort of tune after a cam. Yes. You really don't know what kind of headache a k member install can be do you?
Old 11-22-2006, 01:48 AM
BLKWS.6's Avatar
Man, if you want to DO IT RIGHT, you start from the differential and work up/foreward. You build a car backwards with a goal in mind. Get a 9" or 12-bolt, depending on how much power you want (9" for ***** to the wall). Then worry about suspension/tranny, then do your power mods.
Old 11-22-2006, 04:27 AM
I guess not figuered since im installing headers might as well do K frame.
Old 11-22-2006, 04:38 AM
I figuered since installing headers might as well install K frame, either way i already purchased the K frame,pacesetter LT,SLP lid, rear corvette O2 sensors. That alone was 1200 with shipping from .WS6STORE.com I been thinkin about a ram air hood thats on ebay for about 900+shipping .
Old 11-22-2006, 02:59 PM
cws T/A's Avatar
when you get the k member off , drop the oilpan and change the rod bolts to some higher tensile stuff . katech / arp makes some direct replacements. I ve lost a engine to weak reciprocating parts. It failed from the stock bolts .
Asc has ws6 hoods for $695 + shipping .
Old 11-22-2006, 09:14 PM
1999 SS's Avatar
forget the k-member for now, try and return it if you already bought it and the vette o2 doesnt matter either.
id do headers and cat back, gear, ta dff cover, ported TB, ls6 intake, lid, pulley, and a dyno tune nitrous kit ($269).
Old 11-22-2006, 10:08 PM
Do you have the E-addres for the rod bolts.Also if you go to ebay and look up seller us exotics item #110056790374 hes got a so called super hawk hood with heat extractors but claims the cowl induction is 2-inch higher,it looks awesome do you think its worth it?
Old 11-22-2006, 10:15 PM
I am going to my local muffler shop for a dual exhaust set up after the header LT install.(dont i need the O2 sensor for the Lt headers?mine are pretty old 90K mile)What does ta dff cover due/how hard is it to port TB?Dyno tune nitrous kit $269 where can i get that sounds awfully temting
