Lg G5x4 Question?
Old 11-20-2006, 10:37 PM
SPRAYED 01's Avatar
Default Lg G5x4 Question?
I know the specs on this cam are secret and im not asking for them. Im purchasing this cam and would like to know what rpm to set my shift points at. What rpms do these cams make power untill. All other mods in sig except ill be swaping the 410s for 373. Thanks
Old 11-20-2006, 10:46 PM
tim99ws6's Avatar
it's gonna make power clear to 7K rpm. I would set up my shift points according to where the shift drops the rpm to.
Old 11-20-2006, 10:50 PM
N4cer's Avatar
Your heads and intake play a big role in where the "cam" peaks. It's a full setup with many pieces that determine its performance characteristics. Surely it'll pull to 7k. The X3 does.
Old 11-21-2006, 08:05 AM
SPRAYED 01's Avatar
How badly will i be killing the cams potential if i set my shift points at 6700 and the drop to 5900, or will that be okay???
Old 11-21-2006, 08:13 AM
98SS2836's Avatar
I shift my G5X3 At 6400 and trap better and more mph then when I shift at 6700. Id keep your gears too.
Old 11-21-2006, 09:36 AM
SPRAYED 01's Avatar
What would be the hp difference between the g5x3 and g5x4? Just trying to decid if i want to sacrifice hp for drivability. Any one have g5x4 experience and could comment on the drivability.
Old 11-21-2006, 10:49 AM
SPRAYED 01's Avatar
ttttt
Old 11-21-2006, 12:03 PM
PREDATOR-Z's Avatar
10>15 at most
Old 11-21-2006, 01:23 PM
SPRAYED 01's Avatar
If anyone that is running this cam (g5x4) can chime in about drivability and there over all experience with it that would be great.
Old 11-21-2006, 01:30 PM
HumpinSS's Avatar
Its a great cam on the dyno mine made 431/389 and just went 11.32@121 this weekend @ 3600 lbs. I am running 4.56's because its a M6
Old 11-21-2006, 01:44 PM
SPRAYED 01's Avatar
HumpinSS, was that cam only or with heads or intake. Also is yours a daily driver? Hows the around town drivability? Thanks in advance.
Old 11-21-2006, 02:20 PM
HumpinSS's Avatar
Cam only and 90/90. Used to be a daily but not anymore drives fine around town i cant complain about its driveability. Stuff like that is all in the tune
Old 11-21-2006, 02:35 PM
Mikey 97Z M6's Avatar
Not trying to jump down your throat, but that simply isn't true. The heads/intake have nothing to do with where the cam will peak in the rpm range (+/- 100 rpm). Ported heads and a better intake will only add/subtract hp at different rpm intervals, but has nothing to do with where the cam will make peak hp in the rpm range. If what you stated was true, cam manufactures would have no way to tell where the rpm range, for given a given cam, would be unless they knew exactly what setup each individual was running.
A perfect example would be the latest GMHTP article on the ported heads. They tested 6 different ported heads, some with sigificantly different flow numbers, but they all peaked at relatively the same RPM, again +/- 100 rpm.
http://www.gmhightechperformance.com...ads/index.html
Mike
Old 11-21-2006, 02:41 PM
SPRAYED 01's Avatar
Humpin where were you shifting at? How was cold start? how many miles do you have on the cam and what springs are you runnin? Sorry for all the questions, just want to make the right decision on the cam and need all the input i can get.
Old 11-21-2006, 04:13 PM
SPRAYED 01's Avatar
tttttt
Old 11-21-2006, 05:39 PM
HumpinSS's Avatar
6700
its in the tune
12k maybe 2 yrs or so
prc duals
Old 11-21-2006, 10:14 PM
SPRAYED 01's Avatar
Great thanks for the help. If anyone else is running a g5x4 please chim in on drivability, shift points, and valve train components.
Old 11-22-2006, 09:29 AM
SPRAYED 01's Avatar
ttttt
Old 11-22-2006, 10:19 AM
Mcduffys's Avatar
X4 is a nasty cam with a set of 4.10's. It makes power everywhere. The drivability is all in the tune, not to mention the 4.10's help out alot. I shift between 6800-7000 and ran a set of comp 921's. Check into the new PRC/Patriot springs, they both have more seat pressure and are rated for .660 lift.
Old 11-22-2006, 10:25 AM
SSpdDmon's Avatar
Look at your HP/TRQ curve and determine your shiftpoints based on that data AND a gear calculator. I have one if you need it. You can also find one at www.f-body.org/gears.
Quick Reply: Lg G5x4 Question?
