Biggest cam for a 3200 stall?
This is my DD and it'll be the first internal mod. Only other mods are FLP Lt's ORY, and Hooker cat back. I'm getting the stall for free and plan on sending it to Precision to get checked out before I install it. So, what's the biggest meanest sounding I can go? I can live with alot, my old vette would die 1 out of 10 stop lights.
I was thinking the TRak cam or similar to the one PatrickG did on a 110.
Patrick G cam would work well with the lower stall speed. More torque at lower speeds will help flash the converter higher when needed (within reason, it's obviously not going to work like a 4000 stall).
If you haven't yet, read his comparisons between the TRak cam and the 224/224 110+0 cam. Lots more bottom end, still pulls well to 7000.
Also, since I don't see heads in your setup, you may want to get an adjustable timing set and install it 2 degrees advanced, or even 4 degrees as long as clearance allows. Earlier intake valve closing would net you a higher DCR and better low-end response than installing straight up.
