Heads/Cam on a 100K+ car??
Old 11-23-2006, 11:13 AM
Unforgiven1's Avatar
Default Heads/Cam on a 100K+ car??
Just wondering what the thoughts were of putting heads and cam on a 100K+ car for the first time. I'm uncertain on whether I should pursue this or just stop dreaming 'till I can afford a new engine. I'd appreciate your input on this.
Thanks,
Justin
Old 11-23-2006, 03:24 PM
cws T/A's Avatar
If it doesn't use oil / smoke ,then the engines strong .
Offtopic . I used to buy $100 dollar Pontiac 400ci engines from the junkyard ,they might have had 200k but I runem like they were new . I swapped cams ,intakes , putem in behind stalled autos , even sprayed a few of them with good results.
Old 11-23-2006, 05:01 PM
LS1Formulation's Avatar
I have 140K on my LS1 and I'm doing a cam and possibly heads this winter. Not even going to hesitate to do it. All I would recommend if you don't plan on pulling the engine out to do the swap is get a cam that peaks under 6200 RPM due to the stock rod bolts not being very strong.
Old 11-23-2006, 06:22 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
just did a 228/232 w/ TSP LS6 heads on a '97 Corvette w/ 120k miles, should have the after dyno results this week
Old 11-23-2006, 08:49 PM
jeffstar's Avatar
Go for it man, what's to loose?
Old 11-23-2006, 08:52 PM
HOSS's Avatar
Cam here, going with heads soon, hit 123k tonight
Old 11-23-2006, 09:52 PM
blueovalbeater's Avatar
I have had a cam in since 92k now i am at 110k. no burnt oil, and still crisp as hell.
99zman's Avatar
[QUOTE=connecticut]just did a 228/232 w/ TSP LS6 heads on a '97 Corvette w/ 120k miles, should have the after dyno results this week[
did you install the cam yet? how dose it lope? is it a custom grind?
Old 11-24-2006, 04:37 AM
Pimpium57's Avatar
A compression check wouldn't hurt either. As long as that turns out well and it doesn't use/burn oil like the other guys said.....have at it!
Old 11-24-2006, 05:44 PM
mullenh's Avatar
100,000 miles on a car (that is maintained) today still has better tollerances than a new car 25 years ago
Old 11-24-2006, 09:17 PM
Hehe, I'm liking the way you guys think.
Old 11-24-2006, 10:11 PM
~RedLineLs1~'s Avatar
Look at the bright side. If it blows up you have some nice heads, a cam and a new valvetrain to put in a new engine. You would have to buy that stuff anyway, right?
Assuming you don't go with a huge stroker of course.
Old 11-24-2006, 10:39 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
Why not? if it blows it blows! (god that sounds naughty)
Old 11-25-2006, 09:27 AM
GuitsBoy's Avatar
I have H+C on my 110K mile motor. No power loss due to aging what so ever. The heads were off about 12K ago and there was absolutely no cylinder ridge at all, and my oil pressure is still superb (45+ hot idle). These motors will last forever if taken care of properly.
Old 11-25-2006, 10:46 AM
EndlessSummer85's Avatar
I'm planning on getting a cam for mine I want the TSP 233-239. Can't afford heads otherwise I would be doing that too!!! About to his 104k. Besides you would be doing a top-end rebuild, so like everyones already said as long as it doesn't burn oil your good!! I would do it. Just be aware tho that some bolts might be a little resiliant to come out. Especially the head bolts.
