compression with flycutt pistons
Old 11-27-2006, 07:54 PM
fstls1camaro's Avatar
Default compression with flycutt pistons
i have these ls6 heads that are 64cc combustion chamber with flycutt pistons which would lower it 1 to 2 cc so 66cc stock is 64cc would i lose power if so how much.could i just use a thinner gasket to raise compression or put it back to stock compression.
Old 11-27-2006, 09:47 PM
waterbug1999's Avatar
So your saying that you all ready have your pistons notched? And that you have 64cc LS6 heads?
Well, you could have the heads milled some and even a thinner gasket. But, need to know what cam you are running or intend to run to get proper PTV clearances..
Old 11-27-2006, 10:12 PM
DONAIMIAN's Avatar
If you did loose power, I doubt youd notice it. If you want the lost compression back just get the heads milled.
Old 11-27-2006, 10:23 PM
it is a ls2 and also i was wondering does flycut pistons lose compression.
Old 11-27-2006, 10:29 PM
Yea, you will lose some compression if thats all your gonna do.
