question bout TSP heads???
heres the situation, i installed my cam and bout 4000mi later one of the rocker arm bolt broke in the head(i used the a home made spring compressor tool that threads into the rocker bolt hole so i think i weakend them by doing this), so i bought some new heads,2.5 prc, the 243 castings with 2.04 1.575 valves i think, i installed the new heads and this didnt come to my mind till just recently, the pushrods i used are the 7.4 from tsp, are these heads milled at all? should i b using shorter pushrods? and if need shorter ones am i doing any damage to any of my components?
1st Call Tsp 2nd If I remember correctly the recommned is the 7.350's for those heads if they are milled at .030. But If you are worried pull the valve cover and take all of the rockers off then color the top with a marker and put it all back together. rotate the crankshaft a couple of times and then check to see where the mark is. if it is too far towards the headers then you need shorter p-rods, if it's in the middle then you are ok, and if it is to far on the intake side then they are too short. And here is what I'm talking about.HERE YOU GO
