when rebuilding an engine with forged pistons...
Old 12-03-2006, 06:24 PM
half-n-half's Avatar
Default when rebuilding an engine with forged pistons...
is it ok to re-use the factory piston rings, or is it highly advised against?
just seeing how vital new pistons rings and the like are
thanks
louie
Old 12-03-2006, 07:20 PM
macdaddyZ28's Avatar
correct me if i am wrong, but not replacing them is about as smart as using used oil on a new engine. I would replace them no matter the cost, i mean its alotta work , do it right the first time
Old 12-03-2006, 07:46 PM
TheLS1Kid's Avatar
definately without a doubt use NEW rings.
Old 12-03-2006, 08:18 PM
67Ranger's Avatar
yeah, if your going through the trouble of rebuilding your engine, put some new rings in it.
Old 12-03-2006, 09:02 PM
BlackHawk T/A's Avatar
Piston Rings, being a wear item, should definetely be replaced with a rebuild. If you re-use parts like that it would sort of defeat the purpose of a "rebuild" which is to install new parts.
Old 12-03-2006, 09:16 PM
mcamp001's Avatar
Old 12-03-2006, 10:11 PM
ok cool...i was pretty sure, but just thought i would double check... while typing i was kinda thinking to myself "yeah like re-using bearings" but i figured i would ask either way.
thanks
Louie
Old 12-04-2006, 12:56 AM
DONAIMIAN's Avatar
Also, the stock rings, wouldnt fit most forged pistons as they are made to fit a 3.905 instead of the stock 3.898 bore.
