Cam install/valvetrain upgrade questions
Old 12-06-2006, 01:35 AM
mulletwearingtadrive's Avatar
Default Cam install/valvetrain upgrade questions
I am getting a Trex cam soon and I want to get as much info about what I need to upgrade and how to do the install as possible. I know I need to get new valve springs and I am looking into the patriot gold dual valve springs. I also know I need new retainers and it's probably a good idea to get hardened pushrods.
Another thing I was told is that because my car is a 98 I should look into upgrading the rod bolts. Thanks for any information, links, tips, hints, etc.
Old 12-06-2006, 11:26 AM
ShevrolayZ28's Avatar
I'd say you're on the right track. While you're in there you may as well upgrade the timing set, oil pump, and crank pulley.
LS1howto.com has some install details.
Old 12-06-2006, 11:33 AM
can you give me some costs on the timing set and oil pump? Things I can get from sponsors for reasonable prices?
Old 12-06-2006, 12:09 PM
rickyracer25's Avatar
35 for just the chain to about 114 for a double roller set up, oil pumps from Texas speed 99 -140. 199 for a 25% under drive pulley, you might also want to think about getting 4.10s or 4.56s. I just dropped over 1300 for my cam swap to a ms4 and I did all the work.
Old 12-06-2006, 12:13 PM
How did the cam swap go.....how long did it take you?
I currently have 3.73s so I am going to see how it feels with the 3.73s and I might then go with a nine inch with 4.10s
Old 12-06-2006, 12:19 PM
Three days working after work for a couple hours each day. plus I broke two valve spring tools. duooh! total time was about 8 -10 hours. could have been 4-6 at the most except for the stupid tools. and all I can say is OMFG this thing is awesome!!!!
Old 12-06-2006, 01:50 PM
badass, I can't wait to get my Trex in and do some tuning......
Old 12-12-2006, 12:55 PM
I have a new timing chain on the way....and a billet steel flywheel.
So far I am planning on doing the timing chain, oil pump, pushrods, valve springs, retainers, cam, and crank pulley....also the rod bolts. Anything else I need to take into consideration?
