Head Swap ? 3 of them!
Old 12-07-2006, 08:08 PM
dnm12's Avatar
Default Head Swap ? 3 of them!
So I am getting a set of AFR 205 milled .024" with my cam in the sig being 224/224 .581/.581 with 114 LSA.
So my three questions are:
Will I have any clearence issues in terms of piston to valve?
Anything more I need on the parts list?
Anyone got a ballpark on what size pushrod?
-TR6 NGK sparkplugs
-GM head bolts
-GM MLS gaskets
-GM OEM or Caddy Lifters
-Oil/Oil filter
-Pushrods
-SVO 30# injectors
Stuff:
-Tons of towels
-Comp Pushrod length checkers
-Redline assembly lube
-Fluids (oil and raidator)
-Plastic ice-scraper
-Valve covers and coils delt with (i am 98 with perimeter bolt)
Afterwards:
-Dyno-Tune
Old 12-07-2006, 11:46 PM
dnm12's Avatar
somebody help please!
Old 12-08-2006, 01:08 PM
dnm12's Avatar
-TR6 NGK sparkplugs
-GM head bolts
-GM MLS gaskets
-Oil/Oil filter
-Pushrods
-SVO 30# injectors
Stuff:
-Tons of towels
Afterwards:
-Dyno-Tune
Old 12-08-2006, 03:11 PM
dnm12's Avatar
So any help:
Anyone got a ballpark on what size pushrod? (guessing 7.35)
New updated list:
-SVO 30# injectors
-TR6 NGK sparkplugs
-GM head bolts
-GM MLS gaskets
-Water Pump Gasket
-Comp OEM lifters
-Hardened Chromoly Pushrods 7.35
-2003 Z06 valve covers
-LS6 PCV and valley cover
-Coil brackets
-Dyno-Tune
-Tons of towels, and shop towels
-Lock-tight
-Fluids (oil/antifreeze)
-B-12 Chem-Tool
-Brake Cleaner
-Goodson scraper
-Beer
-Vaccum
-Music/Boombox
-Buddys Garage/Buddy
-Heater
-Time
Old 12-08-2006, 07:04 PM
dnm12's Avatar
worthless.............................
so I got everything ordered except the NGK TR6's......do I need them for the milled heads?
Old 12-08-2006, 07:28 PM
ArcticZ28's Avatar
Go with TR55's, no need for a TR6 in your app unless you plan to spray. You may need a new front timing cover gasket and I'd get a pushrod length checker to figure out what size you need.
Old 12-08-2006, 07:30 PM
dnm12's Avatar
thanks for chimming in, got the pushrod checker on there and dont plan on going behind the front cover, water pump only
Old 12-08-2006, 07:35 PM
Ls1Envy's Avatar
look at my thread....
Old 12-08-2006, 09:10 PM
dnm12's Avatar
where?
Old 12-08-2006, 09:13 PM
ArcticZ28's Avatar
Just Look At It!
Old 12-08-2006, 09:15 PM
dnm12's Avatar
Originally Posted by ArcticZ28
Just Look At It!
https://ls1tech.com/forums/showthrea...6&page=2&pp=20
alright, found it I have even posted on it, which is just bad, but yeah main thing I am concerned about now is ptv clearence, and my assumed pushrod length of 7.35 (dont worry I am going to measure)
Old 12-08-2006, 09:39 PM
Ls1Envy's Avatar
i think you will be fine with that cam. My cam is supposed to clear and I have a 230/232 114LSA with 62cc AFR's. I'm going to check anyway, but I think we'll both be fine. Also your cam is smaller than the 224/228 which clears. No worries brother!
Old 12-09-2006, 12:00 AM
dnm12's Avatar
cool, cool I will still put one head on and then spin the motor just to make sure but thats what I want to hear Ls1Envy
