Valvetrain replacement on 551/551 cam
Old 12-09-2006, 09:46 AM
Function>Form's Avatar
Default Valvetrain replacement on 551/551 cam
DUR @ .050" 216*/ 224*
LIFT .551/.551
OVERLAP 53*
LSA 115*
can i get away with ls6 springs? what else in the valvetrain would i need to replace?
Old 12-09-2006, 10:31 AM
00HARDZ28's Avatar
For the price and the time your gonna waste you might as well do 918 springs just to get it out of the way not that big of a deal IMO Good luck
That way if you wanted to go with a bigger cam dont have to worry about changen the springs agian to match the cam.
Old 12-09-2006, 10:35 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I'd go with 918s with that cam...although the LS6 springs might handle the lift, they might not handle the ramp rate. Since that is a Crane/Vinci cam, I'd ask them. Valve springs are not something I'd cheap out on being that they are so critical to the engine's operation.
Old 12-09-2006, 12:49 PM
vettenuts's Avatar
I would go 918's as well, I have the same cam
I am currently running that cam with PSI beehive springs, it will run forever in RPM without a hiccup so the 918's would be a great match.
Old 12-09-2006, 12:55 PM
JPH
JPH's Avatar
that's a crane #1449561 cam, 918's will be good, but if you are ever thinking about using crane's 1.8 rockers, put cranes #144832-16 springs in it.
Old 12-09-2006, 08:00 PM
mrr23's Avatar
my belief is use what the cam manufacturer suggests you use. why mix and match? use the dual springs that vinci and crane suggests to use.
Old 12-09-2006, 11:32 PM
SSTYCOON's Avatar
LIFT .551/.551
OVERLAP 53*
LSA 115*
I got some brand new yellow ls6 springs for sale @ 60 $ shipped. there good to 570-580 lift. send me a PM if your interested.
Old 12-10-2006, 01:18 AM
BriancWS6's Avatar
Comp 918s would be my choice for your application.
Old 12-10-2006, 03:43 PM
joelvette's Avatar
i've got that cam and 918's on my 6.0 for my 73 firebird. don't have the motor done yet. anyone got a good sound clip? vinci only has it at idle.
