Best cam for 59cc heads?
Old 12-10-2006, 10:10 AM
juice12ufo's Avatar
Default Best cam for 59cc heads?
I'm looking for opinions on what cam to go with my Patriot stage II LS6 style heads (59cc chambers). DCR is a bit tricky with these heads, so what are some proven combos with these heads? I'm looking for power under the curve more so than peak HP numbers.
Old 12-10-2006, 10:24 AM
erikthegoalie's Avatar
228R i think not sure about flycuttin though with that chamber..
Old 12-10-2006, 11:28 AM
juice12ufo's Avatar
I was considering the 228R actually. I don't think it will require flycutting, but if anyone has this setup I would love to hear what you have to say.
Old 12-10-2006, 04:39 PM
93ChevExt5.7's Avatar
Have 59cc 205AFRs with G5X2 - no flycut. (LSA on G5X2 is 114)
Old 12-10-2006, 05:18 PM
Charles Cyrus's Avatar
I have a F-13 with 59cc PP stage II 5.3s. With a 100 shot-507RWHP/451RWTQ.
Old 12-11-2006, 05:35 AM
juice12ufo's Avatar
I'm now considering a 228R on a 112 +2 LSA. That'll drop my dcr to a nice safe number.
Old 12-11-2006, 06:01 AM
98SS2836's Avatar
I have a g5x3 on a 112 no fly cut. I have 300+ ftlbs at 2500 and it just climbs from there.
Old 12-11-2006, 06:30 AM
crazylane's Avatar
Whats the spec's on that cam?? Thanks
Lane
Old 12-11-2006, 07:25 AM
PREDATOR-Z's Avatar
Lane
234/242, .600/.610 112
Old 12-11-2006, 09:51 AM
crazylane's Avatar
I have 59cc, patriots stage 2's so will this cam be fine without fly cutting?
Old 12-11-2006, 11:29 AM
PREDATOR-Z's Avatar
No, this one will need flycut due to the larger valves (especially if they have Ferrea)
Old 12-11-2006, 11:41 AM
crazylane's Avatar
ok thanks for the info. do you think that would be a good setup??
Old 12-11-2006, 12:25 PM
juice12ufo's Avatar
So if an F13 fits, then the 228r should fit. The only difference may be in the heads. Does anyone know about the patriot heads, whether they are welded to smaller CCs or milled? I think I've heard that they are welded, so they really won't have many clearance issues, especially a cam like the 228r
Old 12-11-2006, 12:31 PM
2000TransAmWS6's Avatar
^you're right, they are welded
i'm not a big fan of 2.02 valves, they do eat up alot of piston to valve clearance, and to me they don't flow much more than the 2.00 valves to be worth the hastle... i just got Patriot 243s milled alittle bit.
Old 12-11-2006, 12:36 PM
PREDATOR-Z's Avatar
Yeap, maybe 5rwhp
But whowever wants the 6.0 "LS6 style" welded heads, I'm almost positive if you talked to Gunnard at PP that they could fit stock valves in those. Then the G5X3 would fit (at least the 114LSA).
Old 12-11-2006, 02:50 PM
eamador11's Avatar
My cam is the best. get my cam.
224/228
Old 12-11-2006, 03:12 PM
pdd
pdd's Avatar
224/228
uhh, why is yrs the best, please do tell
Old 12-11-2006, 06:48 PM
98SS2836's Avatar
Try that patrick G torque cam. That would be kick *** with those heads And fit like a glove.
Old 12-11-2006, 08:58 PM
juice12ufo's Avatar
Specs?
Old 12-12-2006, 06:30 AM
98SS2836's Avatar
Originally Posted by juice12ufo
Specs?
I dont know the full specs you would have to pm him but it is
224/228 .637/.639 110LSA. Makes bad *** power under the curve too.
Quick Reply: Best cam for 59cc heads?
