How to clean a piston?
Old 12-10-2006, 06:45 PM
CamminV6's Avatar
Default How to clean a piston?
What is the best way to clean a piston head? I've been told oven cleaner works, but without using something to scrape with, It's not working too well. I'm afraid to scrape the piston, but that seems to be what it's going to take....
Any ideas?
Old 12-10-2006, 06:50 PM
IBM/M6's Avatar
fine steel wool. and small wire brushes . a dremel with the right wire wheel helps . mix some tide detergent into the mix with a little water like a paste .
Old 12-10-2006, 06:51 PM
Sawzall and Welder Mod
Whistler's Avatar
You can use brakekleen with a single edge razor for the flat parts, and a scotch brite pad for the valve reliefs
Old 12-10-2006, 07:31 PM
vettenuts's Avatar
I used a bamboo chop stick. As a matter of fact, I am using the same thing on a set of heads right now. The carbon will chip off with the chop stick and it won't scratch anything.
Old 12-10-2006, 07:36 PM
Studytime's Avatar
Why not use something metal? Just take any kind of scratch out with a scotch bright pad.
My standard procedure is a metal putty knife, varasal, hand scotch bright pad, varasal and then a pneumatic air tool with a scotchbright pad. Clean it in varasal again. It's good enough for 600hp circle track engines, why not an LS1?
Ben T.
Old 12-10-2006, 07:37 PM
Studytime's Avatar
If the pistons are still in the motor, use something to scrape them and then use B12 chemtool on a rag. It works wonders. They'll look new again.
BeN T.
Old 12-10-2006, 08:11 PM
o2man98's Avatar
This is very popular with the snowmobilers that need to clean exhaust power valves and pistons for top end rebuilds.
Powerfoam
http://www.amsoil.com/storefront/apf.aspx?zo=1436102
Old 12-10-2006, 08:35 PM
DuronClocker's Avatar
I don't know if you are referring to the tops of the pistons or the combustion chamber of the head, but I do them both the same. On flat surfaces, I use razor blade, then take WD-40 and a coarse rag or a scotchbrite pad. Scotchbrite pad works much better than a rag does though, especially on the heavier stuff.
Old 12-10-2006, 08:49 PM
pdd
pdd's Avatar
i used wd40-worked great
Old 12-10-2006, 10:38 PM
JLSain's Avatar
Will it hurt anything if I leave the oven cleaner on the heads over night?
Old 12-10-2006, 11:24 PM
dnm12's Avatar
B-12 Chemtool carb cleaner with a shop rag, should clean everything off
