part # for napa gold long filter
Old 12-12-2006, 12:50 PM
jimmypop13's Avatar
Default part # for napa gold long filter
hey, does anyone know the part number for the long filter? thanks
-Chris
Old 12-12-2006, 03:18 PM
jimmypop13's Avatar
well i looked up a truck that had the k&n 2006 long filter that I use on my car and the napa equivilent said 1522 so i'm about to go get one. If anyone else is interested, i can let ya know if its right
Old 12-12-2006, 04:04 PM
Studytime's Avatar
Hey let me know if how it fits. I'm interested in knowing the proper part number.
P.S. How's the TR230 cam treating you?
Ben T.
Old 12-12-2006, 04:24 PM
jimmypop13's Avatar
It's pretty awesome. It sounds great and definitely woke my car up. I drive my car daily and don't have any problems
The oil filter part # listed above was correct. I held it next to my K&N 2006 and it is the same size. the K&N is heavier (probably cuz of the nut) and the top looks a little different. There are 5 holes on the top of the napa filter and they are big. On the k&n, there are 6 small holes. I imagine they are pretty similar & the napa gold is 5 bucks cheaper
Old 12-12-2006, 04:31 PM
Studytime's Avatar
So how much does that make the Napa Gold filter?
Ben T.
Old 12-12-2006, 04:49 PM
EchoMirage's Avatar
Is the K&N 2006 longer then the stock filter? How's the clearance, if it is longer? I use a K&N oil filter but don't remember the number, and it's the same length as the stock.
Old 12-12-2006, 05:39 PM
o2man98's Avatar
FYI: The WIX direct X-ref to the K&N 2006 is the 51045 which would be the Napa 1045, same filter. See it here: http://www.wixfilters.com/filterlook...asp?Part=51045 The WIX filters are available through AMSOIL.
The Long AMSOIL filter for comparison would be the EaO64 and this is what I run on my little 5.3 Silvy. The recommended car size is the shorter EaO32.
Old 12-12-2006, 07:45 PM
jimmypop13's Avatar
i know the napa 1042 & the k&n 1007 is the stock length. I got the 1522 because i went on k&ns website & looked up a truck that uses the k&n 2006, then I entered it in on the napas site and right above the k&n2006 was the napa gold 1522.
i've had no problem with the long filter since i got my car 5 years ago & i've driven over some strange things. A guy ran into me a few weeks ago & my car flew up on the curb. I looked at it on a lift at the body shop a few days later and my engine crossmember was horribly dented but my oil filter was still fine! My headers & exhaust pipes sit lower than the filter also
Old 12-12-2006, 07:49 PM
jimmypop13's Avatar
Also, if you use that link to wix's site but enter in 1522 instead of 1045, you get the same thing only the 1522 has an anti-drainback valve and micro rating of 15 compared to the 1045's 25 rating
http://www.wixfilters.com/filterlook...asp?Part=51522
i think i'll stick with my napa 1522 instead of exchanging it for the 1045
Quick Reply: part # for napa gold long filter
