Need Some Help With these Ebay Heads?????
Old 12-12-2006, 02:32 PM
tamikews6's Avatar
Default Need Some Help With these Ebay Heads?????
How about these heads. I won these the other day but don't know **** about them. They looked like a pretty good deal. I will be running the tr224/112 cam. Can I use stock pushrods or do I need to go shorter? Will I still be able to run 125 dry shot? Is there anything else I should do to these heads before I put them on? What kind of gains could I expect from them?
Heads
Old 12-12-2006, 02:42 PM
C5 Forever's Avatar
#853 casting? What is that?
Old 12-12-2006, 02:47 PM
SOMSS's Avatar
Not much information there to go on. He gave you no clue to the condition or the extent of the porting. It would be nice to know what their flow rate looks like so you can match a cam to them. I'd say your in the dark and just will have to take them to a reputable shop to evaluate them.
Old 12-12-2006, 04:18 PM
vettenuts's Avatar
Are the 853's centerbolt or perimeter? (I don't remember) and which do you have? The add states they are not run, but they have a gasket piece stuck to them and oil dripping, although the combustion chambers appear clean.
Old 12-12-2006, 05:06 PM
tamikews6's Avatar
Thanks I guess I will just have to take them to a machine shop and get them checked out. As far as the gasket and oil he said he used them as an engine mock up. Not to sure what that means. Do you think its true about the parts being more then $300.00? I have a 2002 ls1, will I have a problem useing these heads on my engine? Thanks for the help.
Old 12-12-2006, 05:09 PM
adillhoff's Avatar
853 are center bolt
Old 12-12-2006, 06:32 PM
Moderator
davered00ss's Avatar
You have better heads on your car now.
Old 12-12-2006, 06:33 PM
GuitsBoy's Avatar
806 are the perimeter bolts. 853 are similar to 241s exceptthey used regular sand casting. Nothing wrong with those castings, however we dont know whats been done to them since they left the factory.
Old 12-12-2006, 06:35 PM
Moderator
They were milled .030, so they will bump your compression. You will probably need to run 7.35 pushrods.
Old 12-12-2006, 06:51 PM
tamikews6's Avatar
I am talking to the guy that sold them to me and trying to get the number of the guy who did the work to them to see everything that was done.
Old 12-12-2006, 06:54 PM
Studytime's Avatar
I bet they'll flow close to 245 cfm. Looks like you got a nice set of fresh heads. They have fresh valves, a new valve job, and a good surface for the head to seal to the block.
Now all they need is to be sent off to get ported.
Ben T.
Old 12-12-2006, 08:26 PM
DuronClocker's Avatar
Nothing wrong with 853's, I'm making 421/400 through a set of ported ones (2.02/1.575 valves) and a 224/228 cam
Old 12-12-2006, 09:28 PM
tamikews6's Avatar
This is the response from the seller
the heads came off a 2000 model trans-am with 20,000 miles on them. i had him put 2.02/ 1.60 valves in them, he used a machine that can also open up the shroud under the valves. they have not had any more port work done to them. they were also shaved .030. i can get a number for the shop but i doubt he can tell you anything about them, it has been a year since they were in the shop.
