View Poll Results: better DD low end 402 cam 11.3:1
TSP233-239 .598-.603 113+1
11
21.15%
COMP CUSTOM 242-248 .610-.615 114+4
41
78.85%
Voters: 52. You may not vote on this poll
402 cam pick one
Old 12-14-2006, 11:07 PM
camarokid94's Avatar
Default 402 cam pick one
well i have the 233-239 .598-.603 113+1 tsp on my 346 11.3:1SCR 8.5DCR for the fun of it i called COMP and they said a 242-248 .610-.615 on a 114+4 is what they said to do. for my new 402 it will hav the same 11.3:1 8.35:1DCR my only fear is this new cam will have a way lower DCR and nothing for bottom end.
it needs to be a DD and im keepin the AFR205s and 1 3/4 headers.
what you all think
Old 12-15-2006, 01:36 AM
Pwebbz28's Avatar
A stroker is going to have more "bottom end" than you need anyways. Comp is right. Call HPE and get a Big E cam from them. 244/248 .612 .615 that cam made 470hp and 470 tq in a buddys 408 with STOCK 241 heads. Torque curve was very flat and drove great with 3.42 gears. With 3.90 gears it was insane, you couldnt get it to hook for ****.
Old 12-15-2006, 07:14 AM
slow trap's Avatar
i say get the 242/248 also.with the 205 heads you will have very high velocity/torque and still put up decent hp numbers also.i've got a 244/248 on a 110 +1 to go in my 408 .
Old 12-15-2006, 10:06 AM
tony mamo said to keep the 233-239. i have been lookin at a fast and he said those are a better combo.
Old 12-17-2006, 09:45 PM
getusum's Avatar
look at my cam....244/250 630/630 114+2 originally 595.595 1.8 helped me out....great dd cam and it loves the upper rmps....hp and #'s in sig
Old 12-18-2006, 08:58 AM
CHRISPY's Avatar
You have 11.54 comp and 8.42 DCR with the 402, 66 head cc, 7 thou out of the hole flat top pistons and .052 gasket thickness.
That is using the 242/248 114+4 XE-R cam. Should be a good combo on pump gas.
The smaller cam calcs out to: ~8.58 DCR (I used comp XE-R lobes in my calcs)
Both would be good cams, I actually like the smaller one as well. I think it'd give more area under the curve from 1800-5500rpm where you will do the meat of your driving. (If it is a street car)
Both would work fine though imo, depends on where your powerband preference is
Old 12-18-2006, 10:23 AM
11 Bravo's Avatar
Old 12-18-2006, 11:15 AM
lilbuddy1587's Avatar
239/246 .649 .614 110 or 110+2
(2130 LSK/ 3733 XE-R)
Old 12-18-2006, 05:21 PM
well my heads are 61 im usin 10 out of the hole and ill be useing .040 gaskets adn 12cc dish pistons 6.125 rods and yes there both on X-er lobes.
i want bottom end im ok with less up top
yeah i goin 233-239 better street if i need top end ill turn the bottle on HEHE
or get a FAST 90/90 ported for more topend
Old 12-18-2006, 10:53 PM
Bandit28's Avatar
go big or go home
Old 12-19-2006, 03:03 PM
yet another get the biggest cam you can guy weird......
Old 12-25-2006, 09:45 PM
03 BUSA's Avatar
242/248 gets my vote.
Old 12-25-2006, 10:19 PM
Rhino79's Avatar
I built a 408 with the 233/239.....awesome torque and good power, but that was with a stock truck intake and throttle body, now its getting the VIctor Jr. and 4bbl throttle body as well as probably the 244/248 110lsa. The only reason I went with the 233/239 anyways is to try to keep the pwerband within the range of the truck manifold. Go with the 242/248!
Old 12-26-2006, 03:39 PM
LS1TECH Sponsor
Steve Burger's Avatar
I voted for the larger cam. But then I just installed a 247/247 .656 111 LSA in a 347.
Old 12-26-2006, 03:43 PM
AintQik's Avatar
I had a .248/.254 and I hated it. Really flat. Went with a .236/.242 and it screams. Bigga aint always betta.
402
ET Heads
11.88:1 comp
Old 12-26-2006, 07:45 PM
thank you
now im torn i cant decide now, the DCR of both is pretty close i dont wanna go alll biggest as i can but........ maybe it wont be so bad... just might have enough topend i wont need to invest in the FAST 90/90 HHUUUMMMMM
Old 12-27-2006, 09:46 PM
i hate to do it but think im going big GGRRR
Old 12-28-2006, 07:51 AM
Bader-X's Avatar
to me .... wanna smack and pull better past 6000 rmp and when you change to the next gear go with a bigger cam .... want better idle vacuum and a tamer idle and traffic light easy running stay 233-239.
the 233-239 cam is in a 346 .... now he has a 408 so the same cam is ok? I know it will work but I mean for the added stroke and different short block motion could you have a 233-239 cam ground on something with better specs (if there are others than what I`ll say) other than the the duration@50 maximum lift and lsa and icl where both the standard 346 cam and the 408 cam will be the same?
sorry just had to ask maybe it`s stupid! maybe I`ll learn something for a stroker build.
Old 12-28-2006, 11:32 AM
Race your car!
JL ws-6's Avatar
I am running something very similar to the comp you have listed in my 402, but it's on a 112 +2 lsa I'd go with that.
Old 12-28-2006, 02:59 PM
Im Thinkin Teh Same Something More Like A 112+2 Maybe +4 Keep My Dcr Up
