Wanted 400 HP cam for cam only set up!
Old 12-17-2006, 07:53 PM
nvrlast's Avatar
Default Wanted 400 HP cam for cam only set up!
So some of you may have seen my post from a few days ago asking about the MTI X1 Cam. But I want to consider other options as well because I've seen results very from 380-415 hp. I dont care about the drivability i mean i want it to be street friendly but not really worried about fuel milage and stuff. I also would like to run the factory gear if I can because I like that Hight way gear. My goal is to make awsome hp and torque with the cam I've seen some setups where it's like 380 hp and 350 ft lbs of torque but that aint enough for me I want like 400+ Hp and at least 380 ft lbs of torque. Please let me know if this is achevable and im not just thinking crazy! Thanks guys.
Old 12-17-2006, 07:59 PM
Red99TA's Avatar
There are TONS of cam-only cars putting down 400/380+...just do a search. For reference I dynoed 398/360 but that was with a super lean 14.2:1 AFR and that was also before my ported TB and underdrive pulley. I'm confident that with my fixed tune and those 2 mods that I would be around 400/375
Old 12-18-2006, 07:21 AM
slow trap's Avatar
go with something like a 228/232 on xer lobes on a 110 or so and you will be happy.there was a few threads on that size cam recently with great results.a few may have been +1 or +2 ,i can't remember.
Old 12-18-2006, 07:32 AM
TXZ28LS1's Avatar
something in the 228 range might get you close. im pretty sure that X1 u were looking at will definitely get u close to 400rwhp.. if you want 400rwhp for sure go big like the ms3, g5xx cams.
Old 12-18-2006, 08:31 AM
JRracing's Avatar
I had a TR 230/224 on a 110.5 lsa and it made 390 at the wheels.
Old 12-18-2006, 08:46 AM
slt200mph's Avatar
Made over 400 rwhp with a 233\233 .598\.598 112 with bolt ons no pully and throught the muffler..
Old 12-18-2006, 09:42 AM
hardtopz28's Avatar
made 401 mustang dyno s-cam
Old 12-18-2006, 01:14 PM
Keego_Ridah's Avatar
my car makes close to 400hp on a mustang dyno cam only, with a blown out stock clutch
Old 12-18-2006, 03:00 PM
xeno's Avatar
I made 422/392 cam only on a G5X3.
Old 12-18-2006, 03:07 PM
on a dynojet?
Old 12-18-2006, 03:37 PM
12secSS's Avatar
A couple of weeks ago I tuned a cam-only M6 F-body that made 415/400 on a DynaPack dyno. It just had PaceSetter LTs & ORY, aftermarket exhaust, a lid and a custom Comp Cam (228/232, .58x"/.57x", 112 LSA +2 IIRC). Plus it idled on pretty much the stock settings.
Old 12-18-2006, 03:50 PM
pontiac's Avatar
have a X1 and am over 400rwhp,with out a pully, and threw a 9"
Old 12-18-2006, 03:58 PM
gettinthere's Avatar
We cut a custom cam for a customer (233/239). Cam only he put down 408 thru a 6 speed on our Mustang Dyno.
Old 12-18-2006, 04:55 PM
purdueranger's Avatar
G5X4 cam only FAST 90/90, LTs, 4" mufflex through a 12bolt with 315 DRs and put down 408/379 with maxed out stock injectors.
Old 12-18-2006, 05:12 PM
SunsetHawk's Avatar
How is the streetability of all of these cams putting down over 400rwhp?
Old 12-18-2006, 05:18 PM
my car is preety smooth, but the clutch has gotta go!
Old 12-18-2006, 06:47 PM
nvrlast's Avatar
Yah basicly i want to be pretty much garanteed to make over 400hp to the wheels and want to run the stock 3.42's. So wich one of those would work?
Old 12-18-2006, 06:51 PM
FBGSU02's Avatar
i have MS3 cam i put 415/375 to the tires on cam only. it gets 21mpg on the road and i have 4.10's. its crazy it hauls *** and gets fair gas mileage it was dnyo tuned on a dyno jet at carolina auto masters by jeff creech
Old 12-18-2006, 06:57 PM
Zach@Texas-Speed's Avatar
Go MS3 or MS4, both consistant cams....alot of people daily drive them without issue and most of the time will make 400+, we just did a Z06 that made 440/409 with MS4, headers/orx, UD pulley, intake and tuning.
I've even seen a few make 400+ through an LS1 intake. Do a quick search on "MS3" or "MS4" and take a look at what you come up with.
Old 12-18-2006, 07:01 PM
FBGSU02's Avatar
i agree cant beat texas magic stick.
Quick Reply: Wanted 400 HP cam for cam only set up!
