Which Oil pump and timing set?
Old 12-19-2006, 02:39 PM
HataErasa's Avatar
Default Which Oil pump and timing set?
What recommendations do you guys have regarding oil pumps ad timing sets.
I understand most pumps are just ported factory pumps, is there a completely newly designed pump and if so has there been much sucess with it?
As far as timing sets, there are a few double roller sets out there but I am not looking to do alot of fabrication unless there is significant justification for it.
Any suggestions and comments are greatly appreciated, especially from any engine builders out there.
thanks in advance
Old 12-19-2006, 02:43 PM
2000TransAmWS6's Avatar
Texas Speed has the best prices on LS6 oil pumps (ported and shimmed) that i've seen on the internet, they also have very good prices on timing sets.
alot of people just get LS2 timing chains, they cost about $25-35,... but i got an adjustable timing set so that i could degree my camshaft.
Old 12-19-2006, 03:38 PM
PICNIC_GEORGE's Avatar
Has there been any problems using the stock f-body oil pan with these ported and shimmed pumps? They aren't sucking the pan dry at 7000rpms are they?
Old 12-19-2006, 03:45 PM
Cobra4B's Avatar
I'm going w/ an LS2 chain and the GM chain damper for my Z06 when I put my G5-X2 in. The LS2 is far beefier than my stock chain and it's been fine for 70k and over 30 HPDEs.
For oil... LS4 pump baby... cheap and high output. Should perform great w/ my oil cooler in and when the oil gets thinner as it heats up.
Old 12-19-2006, 07:04 PM
BBBBadSS's Avatar
You just replace the chain and not the sprockets.
Old 12-19-2006, 07:57 PM
dlc1609's Avatar
katech offers a replacement chain also. you use your factory sprockets. they say it's used on the c5r race car and to their knowledge, none of these chains have ever failed. i'm thinking they are $100 or a little more though.
Old 12-20-2006, 10:23 AM
HataErasa's Avatar
I hear the ls2 chain is a double setup, what benefit if any is that? and is it adjustable?
Old 12-20-2006, 10:27 AM
JPH
JPH's Avatar
MELLING #10296 pump, and JP PERFORMANCE #5615T chain set.
Old 12-20-2006, 10:38 AM
HataErasa's Avatar
is the melling a completely new design and does it tuck under the cover properly?
Old 12-20-2006, 10:39 AM
Cobra4B's Avatar
No... it's a single roller... but beefier w/ thicker links.
Old 12-20-2006, 10:44 AM
HataErasa's Avatar
does it require modifying the cover or is it a drop in setup?
Old 12-20-2006, 10:49 AM
00454sscamaro's Avatar
i got the double roller and ported ls6, but after all the hassle of it i would of much rather gone with a ls2 with new sprockets and ported my own pump(wich i ended up doing anyway).. the double roller isn't bad if you have done it a few times and have access to phillips machine screws. but i think the ls2 chain would be plenty. all it's turning is the cam. not like the older chevy's.
Old 12-20-2006, 10:50 AM
GuitsBoy's Avatar
Im running just fine with a home ported and shimmed LS6 pump and an LS2 timing chain. Less than 100 bucks for it all. What kind of setup are you running?
Old 12-20-2006, 10:55 AM
HataErasa's Avatar
eventually it will be a 383 , as of now 233/239 cam 1.8 shaft rockers, but I want to buzz it to 7000+ k if I can as I await the funds for the 383. Stability is key here I feel but as I am making a hybrid setup I am not looking for anymore fabrication than I have already filled my plate with.
If the melling drops in with no problems then I would be interested in going that route just for the extra volume and pressure, but if it screws with the chain then I would not think it such a hot Idea
Old 12-20-2006, 11:19 AM
1LoudTA's Avatar
LS4 OIL PUMP (yes ls4 the new 5.3L LSX motor in the fwd impala ss) dont go any other way, more pressure and volume than an ls6 pump, have one in my car and its great.. get it from www.fredbeansgmparts.com
and its cheaper also only 62 bucks
Old 12-20-2006, 11:31 AM
HataErasa's Avatar
Did you change the cam sprocket with the ls2 chain?
Old 12-20-2006, 11:51 AM
Cobra4B's Avatar
I 2nd the LS4... that's what's going in my car! No need for new sprockets w/ the LS2 chain.
Old 12-20-2006, 03:33 PM
JPH
JPH's Avatar
melling is a direct replacement, drops right in. the jp performance timing set is to, and comes with the proper shims to clear block surface and the oil pump.
Old 12-21-2006, 03:19 AM
BirdmanLS1's Avatar
And the LS4 pump fits in just like stock? no fabrication needed?
Old 12-21-2006, 03:47 AM
Restricted User
WS6nJAX's Avatar
just installed a slp pump and ls2 chain only. so far so good. there really is a big difference between the stocker and the ls2 chain.
