Is a 4.125 stroke to much for a street engine
Is a 4.125 stroke to much for a street motor?
My current combo is a 422
I am using a lunati crank 4.125 stroke
Lunati pro billet Connecting rods 6.125
ross pistons 4.030 bore.
What I am curious about is can this combo last long in a street car or should this be a all out max effort drag motor?
I am just trying to figure out if I should put anymore money in this pit or call it a loss as I like driving the car alot and don't want a straight up drag car.
Thanks for any input.
Hmm Is it not uncommon For this combo on a street motor then?
When we took this thing apart the pistons had some skirt wear and the bearings were beat to ****. I just don't want to invest the money if the combo won't last me a season or two.
I have it at a large shop and they are telling me this is not a very street friendly combo and it will wear and tear fast. I should only use it in race applications with the short piston skirt design.
A common problem with 4.125 stroke setups is they allow the piston to come out of the bottom of the bore too much causing the piston to rock increasing ring wear and eventually resulting in more oil consumption.
Using the correctly designed piston is the way to go in a long stroke street motor. I talked to Brian at Wiesco about this with my motor. In this instance, I would call him and get a piston designed around the stroke. It can be made to last, you just have to have the correct parts. I would not build it again with the kits Lunati/JE pistons.
Ok, I'm confused. For a given stroke, rod length, and block deck height, there is only one pin location. If you want to change the pin location you have to change one of those dimensions. You can change the ring location relative to the pin (within limits), but that's it. If I have this wrong, please explain.
LS1TECH Sponsor
4.125" stroke
You are correct about the pin location. The only way one can move the pin higher is by lengthening the con rod. This of course bunches up the ring pack and can not be done if the pin is already as far up as practical with a 6.125" rod.
A longer sleeve is recommended to run a 4.125" stroke without problems. I had Darton increase sleeve length to 5.800" for all applications last summer to allow the longer strokes to be run in street applications. A longer sleeve provides the necessary skirt support at the bottom of the stroke.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
